Author Topic: Rear brake discs MK6 golf  (Read 2093 times)
Offline passant
« on: 22 November 2013, 19:49 »
What size spline socket do I need to remove my rear brake discs?
Does anyone know I think it's an M14, or does anyone know another name for it as no one / no where seem to stock spline sockets!
Alternatively I need these brakes doing ASAP does anyone know how much these will cost to fit?
Help ASAP
Golf GT TDI 140 - Remapped & Refurbed Vancoovers.
Offline DaveW
Re: Rear brake discs MK6 golf
« Reply #1 on: 22 November 2013, 20:57 »
Calipers or discs?
I haven't looked at mine yet but the old MkIV had Allen headed bolts on the calipers, and the disc was held with a crosshead screw. On the MKIV it's a simple job to change over.
This might help:
http://volkswagen.workshop-manuals.com/golf-mk6/index.php?id=106
http://volkswagen.workshop-manuals.com/golf-mk6/index.php?id=91
DaveW.
Offline mustard
  • Mk7 R
« Reply #2 on: 22 November 2013, 20:59 »
My Mk6 has an Allen headed screw holding the disc to the backplate
Offline Mattyj
« Reply #3 on: 23 November 2013, 03:31 »
You have to remove caliper and carrier to get to disc off these are bolts as in 13mm and 15mm i think then there is a torx retaining screw holding disc on to hub my disc was stuck to hub so a mallet an chunk of wood was required easy job
« Last Edit: 23 November 2013, 03:33 by Mattyj »
