Author Topic: Smooth door trims  (Read 2934 times)
Offline ALTERNATOR
Smooth door trims
« on: 21 November 2013, 23:55 »
Well, where can I find these? Are they available aftermarket or should I go to the local breaker's yard?
I'm from Romania and I've seen only a few vento's with smooth trims and those were on the road.
Any information, a part number, a tip, would be great :smiley:
Offline CraigBest
  • Golf Gti Mk3 Colour Concept Flash Red
Re: Smooth door trims
« Reply #1 on: 22 November 2013, 13:43 »
Later VR6s came with smooth trim I believe
Offline ALTERNATOR
« Reply #2 on: 22 November 2013, 14:34 »
Not a bad tip. Unfortunately, Vr6's are almost impossible to find around here :sad:
Anyone know a part number?
Offline CraigBest
« Reply #3 on: 22 November 2013, 16:08 »
GL models also had smooth door trim
Offline Foreveryoungaus16v
« Reply #4 on: 22 November 2013, 17:00 »
If yours is a 5 door there is a set on ebay, item 251351753931
163 BHP (TSR POWER RUN)
Offline ALTERNATOR
« Reply #6 on: 22 November 2013, 20:02 »
Those seem textured :undecided:. I'm looking for some smooth ones which I can paint
Offline mad4vws
« Reply #7 on: 22 November 2013, 21:12 »
mk3 gl  tdi 's normally come with smooth same as vr6 ..
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline ALTERNATOR
« Reply #8 on: 23 November 2013, 13:08 »
So mk3 Gl TDI's :smiley:
Thanks man! I'm gonna watch out for those.
Offline gasketface
« Reply #9 on: 23 November 2013, 16:13 »
HI OP.Are you from Romania and living in UK or are you in Romania and wanting them posted out to you ?.Also,are you after a set for 3 or 5 door ?.
