Author Topic: Diffculty selecing first gear (sometimes)  (Read 2037 times)
Offline Shady Pioneer
  • graphic designer.
« on: 21 November 2013, 10:29 »
Here we go, got a problem with the Bora.  :grin:
Most of the time it runs absolutely fine but sometimes, when cold or hot, I can't select first gear, the shifter doesn't go all the way. I have to select reverse and then back into first to get it in. All other gears seem fine.
Anyone got any ideas?
Offline barrym381
Re: Diffculty selecing first gear (sometimes)
« Reply #1 on: 21 November 2013, 10:38 »
sounds like my old mk1  :laugh: try adjusting it
http://www.youtube.com/watch?v=sheTKD03hmo
Offline james2
  • No scammers please.
« Reply #2 on: 21 November 2013, 14:52 »
mine does this sometimes ,have you tryed putting the clutch down, try and get first gear but it will not go in so release the clutch and put it down again and it goes into first gear.  :whistle:  :huh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #3 on: 21 November 2013, 15:14 »
Mine does exactly that! What is it? :huh:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline beppe2672
« Reply #4 on: 21 November 2013, 16:24 »
could be worn synchro's, mine is doing the same, tried adjusting the linkage, no joy.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline km
« Reply #5 on: 21 November 2013, 18:20 »
since having my gearbox rebuilt, 1st and 2nd gears are difficult to select in the morning, once car warms up, they are fine :huh:
Offline james2
« Reply #6 on: 21 November 2013, 18:57 »
Clutch getting old.  :undecided: not sure but it works everytime if i can not get it in gear.
« Last Edit: 21 November 2013, 18:59 by james2 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 21 November 2013, 22:47 »
Try changing the gearbox oil as a first port of call.
  • graphic designer.
« Reply #8 on: 22 November 2013, 04:41 »
Thanks for the input everyone. Gearbox oil first it is.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 22 November 2013, 13:41 »
Mine is a bit stiff until it's warm
