Author Topic: Help with hoses! 1.8T AUM  (Read 2002 times)
Offline the-rabster
  • Mk4 1.8T GTI
« on: 21 November 2013, 08:53 »
Hi guys, looking for a bit of help, basically, my sump has a hairline crack in it along with a split in the hose that goes from the sump to the turbo. Im just wondering if anybody knows this hose part number or what its called? Is it a straight from VW job or can I buy an aftermarket one somewhere?
Cheers,
Robert
Offline Nino
Re: Help with hoses! 1.8T AUM
« Reply #1 on: 21 November 2013, 12:23 »
Do you mean the pipe that is in the sump giving the turbo it's feed? If so this is own as the oil pickup pipe and get a new one from vw around £13
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline james2
  • No scammers please.
« Reply #2 on: 21 November 2013, 14:45 »
He mean the turbo oil feed pipe.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dom
  • Back in a Mk4
« Reply #3 on: 21 November 2013, 16:30 »
This ^
The oil pickup pipe is inside the sump Nino :wink:
Offline the-rabster
  • Mk4 1.8T GTI
« Reply #4 on: 21 November 2013, 17:54 »
Its not the pick up pipe inside the sump, its the braided one attached to the back of the sump. Is this the oil return pipe??
Im on my third sump now.....and the cars not even lowered  :sad:
Offline dom
  • Back in a Mk4
« Reply #5 on: 21 November 2013, 20:56 »
Yes, the one you are referring to is the oil return.
How the hell have you gone through that many sumps? I ran mine with coilovers all the way down for a year without cracking a single one :shocked:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 22 November 2013, 13:58 »
Yes sump return pipe is a separate piece, I'll find you the part number in a mo
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 22 November 2013, 14:02 »
06A 145 735 AA - around £60 new!
You'll also need some gaskets and bolts to go with it
2off N 014 702 13
1off 058 145 757 C
2off N 010 217 23
1off 058 145 757 A
Offline the-rabster
  • Mk4 1.8T GTI
« Reply #8 on: 23 November 2013, 11:26 »
Much appreciated for the part numbers etc :)
As for being on the third sump....Ive got the girlfriend to thank for that, she doesn't realize you have to slow down for speedbumps!!
The aluminium sumps are pretty weak though eh, I saw a few posts somewhere else about the steel bottomed ones? Anybody have these?
Offline mrsaunders
« Reply #9 on: 23 November 2013, 18:10 »
As said it's the turbo return pipe, the feed pipe sits above the oil filter housing, the gasket and bolts will cost peanuts mate
