Author Topic: Ok I've changed the following and still lumpy  (Read 3624 times)
Offline Mk2_tel
« on: 20 November 2013, 18:53 »
Map sensor and maf sensor.
Still getting the spluttering around 2k!!!!!!
However when I changed map sensor today it run sweet for about 25mins
So I'm wondering has it got something to do with gettibg warm?
I fitted a 3bar sensor rather then standard 2.5 got it from darkside developments.
Between 1800-2200revs plays up after is fine.
Wonder if its the actuator on turbo this was a recon turbo fitted by darkside about a year ago?
Any more suggestions be great guys
(Car is tdi130+ custom darkside map)
« Last Edit: 20 November 2013, 19:21 by Mk2_tel »
Offline Rhyso
Re: Ok I've changed the following and still lumpy
« Reply #1 on: 20 November 2013, 21:16 »
Tried cleaning out the EGR valve or have you fitted a delete pipe?
Offline Mk2_tel
« Reply #2 on: 20 November 2013, 21:21 »
I've got the delete mate allard
Offline EsSeX dAn
« Reply #3 on: 21 November 2013, 18:00 »
have a check of the camshaft, the dreaded lobe wear may be setting in
i think i love you.....
