Author Topic: Mk2 ABS help.  (Read 4804 times)
Offline sam j
Mk2 ABS help.
« on: 18 November 2013, 19:08 »
Hi all. Firstly, apologies for the first post / thread being a call for help, only bought the mk2 last weekend and trying to get it back on the road. Its a LHD 1991 4-door.
So, took it for its annual test today, and it failed on the ABS warning light not working. Bit of investigation and someone has disconnected it. Reconnect it and the light comes on with the ignition and stays on.
Now comes the problem, I know that ABS on these Mk2s is pretty rare, my Haynes doesn't even mention ABS. So does anyone have a guide / wiring diagram / anything on the ABS system and how it works?
I'm guessing that as the light comes on and stays on it isn't a wheel sensor. When you turn the ignition on you can hear the brake pump kick in and then go off a few seconds later. Assume this is the system coming up to pressure?
Any tips as to where I should be looking?
Thanks
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Mk2 ABS help.
« Reply #1 on: 18 November 2013, 19:20 »
Hi, checking all the sensors have adequate resistance using a multi meter would be a good start as this will need to be eliminated first. But it could also be caused by dirty fluid or moisture in the fluid. Poor electrical connections or relay. The pump itself could be deffective. Does it have an abs ecu anywhere.
Offline dragonfly
Re: Mk2 ABS help.
« Reply #2 on: 18 November 2013, 20:07 »
I'm sure the abs ecu is in the boot.  If you go onto VAGCAT there is a harness guide.
Offline sam j
Re: Mk2 ABS help.
« Reply #3 on: 19 November 2013, 07:37 »
Thanks for the quick replies.
I shall check the wheel sensors this evening. The pump kicks in and runs when you turn the ignition on, and kicks off again later, and seems to pump fluid (i.e. if you open a bleed nipple on a wheel cylinder it happily pumps fluid out)
As dragonfly says, the ECU is in the boot with a single multi-pin connector. Guess there is going to be quite some wiring to trace, I shall grab the harnass guide from vagcat (thanks for the tip).
Is there any special technique for bleeding these systems for a full fluid change?
Offline Gti_Jamo
Re: Mk2 ABS help.
« Reply #4 on: 19 November 2013, 11:46 »
For fluid change your best just opening the nipples and let it drain while topping up until clean fluid appears. You don't want pump to go dry. You should be able to check all the sensors via the ecu if you can find out what goes where. I had all these issues with my early 92 vr6 and I still could never to get the abs light of all the time but it works 85% of the time. The light going out is always acompanied by a relay click. This assuming we run the same pumps. Teves 2 pump.
Offline sam j
Re: Mk2 ABS help.
« Reply #5 on: 19 November 2013, 12:12 »
I shall have a look, thank you. I had the rear calipers off and rebuilt at the weekend and flushed quite a lot of new fluid through at the same time, will run some fresh through the front whilst I have it in the air later.
Do you know if it is possible to get the ECU to display error codes on the dash? from googling the Teves II pumps it seems that in some systems you can get the error code "flashed out" on the warning light.
Offline sam j
Re: Mk2 ABS help.
« Reply #6 on: 19 November 2013, 19:59 »
I must be missing something - on the wheel sensor connector there is two conductors, and I am guessing I should see some connection either between them, or between one / both and ground? but I see nothing, on either pin, on any wheel... either all 4 sensors are dead, I'm doing something wrong, or my multi is dead (quite possible, had issues with it before...)
I have tested both relays and they work, all fuses are good.
Shall borrow the test meter from work tomorrow and nip home on my lunch break, see if I can get some kind of reading with that one.
Offline Gti_Jamo
Re: Mk2 ABS help.
« Reply #7 on: 22 November 2013, 23:26 »
Your testing for resistence yeah? Not voltage. I know a healthy sensor on a mk3 should hold steady at anything between 1 and 1.3 K Ohms.
Offline sam j
Re: Mk2 ABS help.
« Reply #8 on: 23 November 2013, 06:55 »
Yeah, turns out I have a dead meter. Borrowed the decent one from my lab at work...
FL - 95 kΩ
FR - 1.05 kΩ
RL - 1.08 kΩ
RR - 1.03 kΩ
So dead sensor front left. Managed to source and replace the sensor yesterday, and whilst the light now goes out i have another problem. Pulling away from a stop / at low speeds the brake pedal judders and the ABS relay kicks in and out rapidly as if the ABS thinks a wheel is locked. This happens when my foot is off the brakes only, the abs light stays off, and it stops by the time you get over about 20-25 kph. Any ideas what would cause such an issue?
edit to add: the brakes don't actually engage when the pedal jitters. The car drives fine and pulls away as it should, the brake pedal just randomly moves down an inch or so and then jumps back. Does this anything up to 2 or 3 times a second, then stops.
« Last Edit: 23 November 2013, 07:00 by sam j »
Offline Gti_Jamo
Re: Mk2 ABS help.
« Reply #9 on: 23 November 2013, 18:26 »
I'd inspect and clean up all the abs rings and that should sort it mate.
