Author Topic: help with flashing door pins  (Read 3386 times)
Offline jontom
« on: 17 October 2003, 14:23 »
hi
Has anyone fitted flashing door pins to a Mk3? i got some the other day but have been unable to wire them up successfully, i can get them to flash all the time but can't get them to come on when i lock/alarm the car. any ideas  ???
thanks
Omar
Re:help with flashing door pins
« Reply #1 on: 17 October 2003, 14:31 »
off on a slight tangent - I'm getting a really annoying rattling around the door pin area, what the hell could it be?? and is it that hard to take the door panel off to check it out.
I'm assuming you need to do this to get your flashing door pins installed??  :-\
Offline The VolksWizard
« Reply #2 on: 17 October 2003, 20:24 »
excuse if this is obvious but have you tried tightening the door pins?
Sooooo many are loose and rattle.
Other than that get your door card off but be very careful not to rip the bit thats bonded to the door card off.
Also be careful not to split the vinyl across the top of the door when pulling it out of the slot that runs the width of the windowl.
There is a rod that goes from the door handle to the door lock and that passes through a hole in the door and can rattle a lot.
Good luck, I just sorted a rattle on my dads Polo, it was the air intake pipe!
Offline jontom
« Reply #3 on: 19 October 2003, 11:21 »
After much surching on the internet i found a way of wiring up my flashing LED's.  I've put up a web page on how i did it, so if anyone is interested in doing the same or how i did it can visit this link....
www.digitalgfx.co.uk
