Author Topic: Cam Belt Damage  (Read 2057 times)
Offline Owen GTI
Cam Belt Damage
« on: 16 November 2013, 20:17 »
Hi Guys
Can you tell me if the cam belt snaps on a 2Litre 8v do the pistons get damaged?
Thanks
Offline xionsolaris
Re: Cam Belt Damage
« Reply #1 on: 16 November 2013, 21:54 »
The valves will get bent as they are a lot weaker than the pistons
Re: Cam Belt Damage
« Reply #2 on: 16 November 2013, 23:40 »
Yes they will.
Offline sharki786
  • GOT BOOST??
Re: Cam Belt Damage
« Reply #3 on: 17 November 2013, 06:20 »
Valves get bent as said
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Owen GTI
Re: Cam Belt Damage
« Reply #4 on: 17 November 2013, 10:37 »
thought that might be the case, thanks guys
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
Re: Cam Belt Damage
« Reply #5 on: 18 November 2013, 00:24 »
Hi
My crank bolt came lose and stripped the locating key on the gear which caused the timing to go out. I replaced the belt, adjuster, crank gear with new bolt timed it up did a compression check and run the engine with no unusual noises.
All I can suggest move the crank so pistons are away from tdc take the rocker cover off and rotate the camshaft and hydraulic followers if all looks good and valves appear to be closing ok re time the engine with new parts do a compression check then start the engine with fingers crossed it may be ok.
New toy1990 Scirocco I feel a 16v conversion coming on.
