Author Topic: Wheel Hop  (Read 5359 times)
Offline legg360
Wheel Hop
« on: 16 November 2013, 17:42 »
Been having a look about and cant find much info on wheel hop when accelerating harshly. I did find a website that explains it and says the main cause is worn out suspension bushing, as my car has only done 27k I would be surprised if they are worn out already! The wheels very rarely spin up they mainly hop under full throttle, 3/4 throttle they will grip with no problems. If the road is dam it will hop even more.
Does anyone else have problems with wheel hopping?
Golf GTI MK6 5dr Manual - Candy White with Jacara Cloth, Vancouver 18" Alloys, RNS 510, Cruise Control, Carbon Vinyl Wrap Roof, Milltek 3" Race Cat Back.
Offline Poached
Re: Wheel Hop
« Reply #1 on: 16 November 2013, 18:29 »
First place to start is your tyres.
Stiffer control arm bushes and engine mounts usually reduce wheel hop. The stock bushes are softer so allow for more movement. Stiffer engine mounts will transmit more engine vibrations through the cabin/steering wheel and pedals.
It might not fully eliminate it from a standstill but you should see an improvement.
Any modifications?
Offline legg360
Re: Wheel Hop
« Reply #2 on: 16 November 2013, 18:42 »
None at the mo but plan when got the money for turbo back system air box and remap so can only see the problem getting worse so want to get it fixed before more power is added.
The tyres are some random make on the front so may some better ones in the new year
Offline Poached
Re: Wheel Hop
« Reply #3 on: 16 November 2013, 19:25 »
100% change those tyres and your geometry might need checking too.
You could go for an anti-Lift kit and a Powerflex dogbone insert as upgrades.
If you Google Rubber vs Poly bushes you will find plenty of info.
Offline mkviken
Re: Wheel Hop
« Reply #4 on: 16 November 2013, 20:15 »
Better tyres and beter throttle control will sort it
WALK and torque arm insert make it all but disappear except in very wet/slippy conditions
Golf GTI 7.5 230 white silver
Offline legg360
Re: Wheel Hop
« Reply #5 on: 16 November 2013, 20:50 »
Thanks for your replies... new tyres are defo on the list to get, looking at powerflex bushings and cant find one called a torque arm. I was looking on here as a reference.
http://www.awesomegti.com/car/vw/golfmk6/powerflex-bushes-for-road-use-volkswagen-golf-mk6-5k-2009-2013
Edit: Found them was looking in suspension bushings not engine, is it worth replacing the engine and gearbox bushings as the car isn't really ever gonna have more then 300bhp and wont be used for track only road? I don't really wanna be sitting in a vibrating car if I can get away with slightly softer bushings
« Last Edit: 16 November 2013, 21:41 by legg360 »
Offline RocketRossUK
Re: Wheel Hop
« Reply #6 on: 16 November 2013, 23:22 »
Offline legg360
Re: Wheel Hop
« Reply #7 on: 16 November 2013, 23:31 »
I was looking at these 2 bushings on powerflex website
http://www.powerflex.co.uk/road-series/product-details/Lower+Engine+Mount+Insert+%28Large%29+/1915.html
http://www.powerflex.co.uk/road-series/product-details/Lower+Engine+Mount+Small+Bush/506.html
Then when got some more cash looking at the products down the bottom you mentioned. Problem I got is I listed everything I want to buy for my car and it totals nearly how much I paid for it!!
Re: Wheel Hop
« Reply #8 on: 17 November 2013, 00:48 »
Yeah the top one is right, not 100% what the second one is for but im sure someone on here will tell you soon  :smiley:
Offline Poached
Re: Wheel Hop
« Reply #9 on: 17 November 2013, 11:51 »
Go for the insert, it's what I've got. There is some extra feedback through the steering wheel on idle but it's not OTT.
