Author Topic: Help plz  (Read 1406 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Help plz
« on: 16 November 2013, 17:23 »
Hi everyone
Iv just had a  mk4 golf 1.8 turbo
And my car has started to overheat on the temp gauge on the clocks
Only started today as had car 4 few days now
Out the blue car temp gauge went shooting up to 130 parked up
And coolant bottle goes full
Left bonnet open and temp goes to 90 and heaters work perfect
But the fan doesn't come on
Can someone help me to solve this problem
And also what is the best dumpvalve 4 the car
Also had stage1 remap at r tech : )
Offline barrym381
Re: Help plz
« Reply #1 on: 16 November 2013, 18:06 »
waterpump failure would be my guess  :smiley:
Offline dom
  • Back in a Mk4
Re: Help plz
« Reply #2 on: 16 November 2013, 18:46 »
And mine, I wouldn't drive it until it's sorted.
Offline Gary#turbo
Re: Help plz
« Reply #3 on: 16 November 2013, 18:53 »
But if it was water pump wouldn't the air out the heaters be cold.  ?
Offline barrym381
Re: Help plz
« Reply #4 on: 16 November 2013, 19:24 »
sometimes they still pump some water through the system just not enough  :wink:
Offline james2
  • No scammers please.
Re: Help plz
« Reply #5 on: 16 November 2013, 21:00 »
Hi everyone
I would change the thermostat first. If that does not work its the water pump. Fans come on when hot water gets into the rad.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Help plz
« Reply #6 on: 16 November 2013, 22:17 »
while doing the thermostat you can feel inside to see if the impellor is still there...
Offline Gary#turbo
Re: Help plz
« Reply #7 on: 16 November 2013, 22:21 »
What's the  impellor lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Help plz
« Reply #8 on: 17 November 2013, 11:06 »
The black bit in this pic
It's what circulates the water around your engine. Usually they break apart or come away from the shaft meaning they will only sometimes turn.
