Author Topic: Lower engine mount/ torque arm insert  (Read 1698 times)
Offline AndyWard
« on: 16 November 2013, 17:13 »
Search has not really thrown up anything and neither has google for what am looking for.
Im looking at getting the powerflex insert track or non track is undecided. But have seen a few posts on the web saying that with a dsg the vibes are shocking but then others saying it is fine but this is with an other brands.
Have seen a few of these mounts in peoples sigs. Just looking for some words of wisdom rather than the general rabbling of the web.
Thx
10 Plate, Silver DSG,  APR Stage 2, APR TBE, Carbonio Intake 1 + 2, Bilstien B8 + VWR Springs, Eibach Front & Rear Roll Bars Powerflex Bushings, TyrolSport Subframe Deadset Collars, Whiteline Endlinks Front & Rear, Neuspeed TOP and Intercooler Pipe, R8 Coilpacks,
Offline Neil gti
Re: Lower engine mount/ torque arm insert
« Reply #1 on: 16 November 2013, 18:31 »
Thx
If you've got DSG I would go for the insert rather than the solid mount, I had the solid mount fitted for about a month and couldn't live with it, some say that it settles in time but it did my head in so I removed it  :sad: and fitted the insert
« Last Edit: 16 November 2013, 20:21 by Neil gti »
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline mkviken
« Reply #2 on: 16 November 2013, 20:13 »
I've got one and its good. Makes shift a lot nicer and better throttle response
Very slight increase in vibration on cold start up
Cut the front legs down by half on the poly insert to reduce vibration a lot.
Golf GTI 7.5 230 white silver
Offline AndyWard
« Reply #3 on: 18 November 2013, 13:38 »
Thx
Which insert did you go for in the end?
