Author Topic: Sunroof seal  (Read 14365 times)
Offline clipperjay
Re: Sunroof seal
« Reply #10 on: 16 November 2013, 20:03 »
cheers jay, off to germany i go ............................  :lipsrsealed:
I could only get 10% off that price @ at £56.24 all in!
Well I did over 1000 miles to pick a car in Italy said it all TBF.
I remember buying 20l in Calais of Mobil one for half the price, Euro rate was good back then.
I have though about contacting a VW dealer in Calais at some point myself  :grin:
Offline danny_p
Re: Sunroof seal
« Reply #11 on: 16 November 2013, 23:19 »
wonder what vw prices are like in ruski  :whistle:
all the VW's have gone bar 1.
Offline clipperjay
Re: Sunroof seal
« Reply #12 on: 17 November 2013, 17:25 »
Bring back some vodka it will pay for the seal  :evil:
Offline sam j
Re: Sunroof seal
« Reply #13 on: 26 November 2013, 08:27 »
I don't have an original to hand to measure, but could one of the side seals from woolies trim work?
http://www.woolies-trim.co.uk/c-37-side-seals.aspx
Even the most expensive is only £11ish a meter, and you need ~2.5m for a mk2.
Offline Dave_IOW
Re: Sunroof seal
« Reply #14 on: 26 November 2013, 16:57 »
Think they're all too big, but good idea!
I've blown the front two drain holes out, to try and stop any coming down into the cabin.
Can you access the rear drain holes through the sunroof itself? If not, anybody know where they are supposed to come out? Pressumably in the wheel arch somewhere?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline sam j
Re: Sunroof seal
« Reply #15 on: 27 November 2013, 10:14 »
They do a 6mm rubber edge seal that might be small enough. Otherwise give them a call, they may be able to source something that isnt listed on their site.
As for the rear drain holes. They exist at the rear corners, coming inside to behind the roof lining, where a plastic pipe is attached which leads away to the rear arches. Unless you want to pull the roof lining down you may be best trying to "rod" the pipes from the rear arches. I need to get mk mk2 into the garage this evening, if I remember I shall try to get photos of where they come out for you.
Offline Waspy
Re: Sunroof seal
« Reply #16 on: 27 November 2013, 22:04 »
For the sake of 15quid I might give it a go an let you all know.
Having said that my seal isn't too bad yet, so taking it off might be a mistake ...
Offline Ali MK2 :-)
Re: Sunroof seal
« Reply #17 on: 28 November 2013, 00:32 »
Market Deeping  will find out the name but I got a full boot rubber there....good price  :wink:
Offline Ali MK2 :-)
Re: Sunroof seal
« Reply #18 on: 28 November 2013, 00:34 »
Also looking to get a sunroof seal...That's where I've been advised to go :/
Offline sparkplug
Re: Sunroof seal
« Reply #19 on: 01 December 2013, 21:46 »
i have fitted the woolies part no.113 to mine (great people to deal with very friendly & helpful)
.. BUT although it is water tight ,the fit is not exactly that of the original
1986 GTI atlas grey
