Author Topic: Has any ever used this throttle body  (Read 3110 times)
Offline Shizzle
« on: 14 November 2013, 12:49 »
http://www.ebay.co.uk/itm/70MM-80MM-THROTTLE-BODY-SKYLINE-SUPRA-WRX-STI-FORD-EVO-MR2-R34-R33-GTI-GTO-/320920995163?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab861c55b
Found this on eBay looks the part but will it work i know standard mk3 16v throttle bodies can be modified but is this a easier way to do it.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Len
Re: Has any ever used this throttle body
« Reply #1 on: 14 November 2013, 13:00 »
Why would you want to spend money on that?
You can polish/enlarge the existing throttle body, which will help a littel but you are never going to make much extra power!
There is a very good thread about all of these things.
(sure Wayne will oblige again!)
www.sas.org.uk
www.the-ace.org.uk
Offline Shizzle
« Reply #2 on: 14 November 2013, 13:02 »
Mine is slightly enlarged obviously i don't believe the 10hp gain but throttle response might be better if this is plug and play and works i would just buy this tbh.
« Reply #3 on: 14 November 2013, 13:06 »
Khare did a really good write up on polishing the throttle body.
I suggest using a dremmel too. With a file you're going to be going across the butterfly seat and if you catch it you're going to ruin your throttle body.
Get a dremmel and get some cutters like these
http://www.ebay.co.uk/itm/Dremel-115-High-Speed-Cutter-7-8mm-x-1-FREE-POST-/180705824191?pt=UK_Home_Garden_PowerTools_SM&hash=item2a12e80dbf
http://www.ebay.co.uk/itm/Dremel-117-High-Speed-Cutter-6-4mm-Multipack-/190562510738?pt=UK_Home_Garden_PowerTools_SM&hash=item2c5e692792
As well as a lot of sanding drums, you'll need a hell of a lot of these!
http://www.ebay.co.uk/itm/100pcs-1-2-x-1-2-80-Grit-Sanding-Drums-Bands-For-Dremel-Tools-/370679257885?pt=UK_Home_Garden_PowerTools_SM&hash=item564e349b1d
http://www.ebay.co.uk/itm/DREMEL-432-ROTARY-MULTI-TOOL-13MM-SANDING-DRUM-FINE-120-GRIT-PACK-OF-6-/190779452946?pt=UK_Home_Garden_PowerTools_SM&hash=item2c6b576e12
High speed cutters work well at 1/2 - 3/4 speed
Sanding drums work well at low speed, if you go too fast they'll rip apart prematurely.
Take your time and go steady. Get your gasket and put it up against the intake manifold and see how it matches up to that. Mine happened to fit perfectly to size against the manifold so I used it as a template for the throttle body to match it in size to the manifold, that's the important bit.
High speed cutters first for the heavy duty stuff, then sanding drums once you're trying to smooth it out evenly and carefully, start at lower grit (rough) and work your way to finer sanding material (higher grit). Once you're happy get the polishing wheel and knock yourself out with some metal polishing cream.
Make sure you don't widen your throttle body past the size of the intake manifold, otherwise you'll be creating a restriction and you'll end up having to port the intake manifold too.
Most important thing to remember is you can easily take material away but you can't put it back once you've shaven it off! So cut, measure, check, cut, measure, check, etc.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 14 November 2013, 13:26 »
Save your money mate.
Offline Shizzle
« Reply #5 on: 14 November 2013, 13:29 »
Thats a good write up and for 18.81 for all the bits well worth it thanks.
Offline spikenipple
« Reply #6 on: 14 November 2013, 18:41 »
I have a ported&polished TB for sale  :wink:
VW BUSH
« Reply #7 on: 14 November 2013, 19:19 »
Save your money and mod a spare VW one, I say spare cos you can go to far very easily :grin:
That universal one will need fitting so that you have no steps, may need an adaptor plate and so on.
Offline Shizzle
« Reply #8 on: 15 November 2013, 08:27 »
I have a spare 1 connected to my spare engine  :rolleyes:
Offline Len
« Reply #9 on: 15 November 2013, 13:11 »
There was a very good thread all about power increases for things like throttle body, air box as against K&N cone filter etc.
www.sas.org.uk
www.the-ace.org.uk
