Author Topic: Please help! Coolant leak after thermostat change!  (Read 5892 times)
Offline hardmonkeys
Re: Please help! Coolant leak after thermostat change!
« Reply #10 on: 14 November 2013, 11:43 »
Fair enough. Mine was probably a coincidence then
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline mcgee9t2
« Reply #11 on: 14 November 2013, 12:47 »
Check the oring is in properly and giving the Tstat housing a proper seal.
Offline Gti5382
« Reply #12 on: 14 November 2013, 13:41 »
Re lower stat housing bolt, I found it easier to use 5mm allen in centre of bolt rather than 10mm socket on outside given how snug it is there. Used L shaped allen key for 90% of turns then finished off with allen socket on quarter inch extender/ratchet. Dont forget block is ali and housing plastic! Good luck.
Offline AntMk3GTi
« Reply #13 on: 14 November 2013, 15:43 »
Yeh thanks for the advice, I'll try the Allen key and get a good grip on it to try and tighten the bolt a bit more.
I used a 10mm socket on a long extension, the scket was conencted to one of those swivel joints. It was difficult to get a good grip on the bolt but when I could, i could use the ratchet with a lot of space.
The allen key will have a better connection to the bolt, if I can get enough space to give it a good turn and tighten.
You say the block is ali and the housing is plastic, is this something I need to take into account when tightening? sorry not sure what you meant about that. Could I damage the block or something?
cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 14 November 2013, 19:02 »
you can crack the housing if you over tighten it
Offline Chambo
« Reply #15 on: 14 November 2013, 23:00 »
Are you sure the old O ring has come out of the recess,you could have 2 O rings In there causing it to leak.
Offline AntMk3GTi
« Reply #16 on: 15 November 2013, 10:30 »
Yeh the old O ring definitely came out, I compared it with the new one to make sure they were the same. then I definitely put the new one in.
After checking this morning though, the leak seems that have slowed down. I drove home after work yesterday (about 30 mins) and only had to top up about 1/4 of a litre, then drove in this morning (over an hour i rush hour traffic) and no coolant warning light.
I'll check later to see how much coolant I lost, but it's strange that the leak has slowed, because before after driving off, the warning light would come on after about 10 mins.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 15 November 2013, 13:36 »
Water seals can stop leaking over a little bit of time, I'd still be wanting to find the problem though, you don't want it suddenly dumping all the coolant out when you're out on a long drive
Offline AntMk3GTi
« Reply #18 on: 15 November 2013, 14:39 »
Yeh suer i'll be looking for the cause of leak.
I'm going to check the bolts tomorrow, being careful not to over-tighten or crack the housing (if it hasn't already).
I wont buy a load of coolant until I'm sure the leak has stopped. Is it easy to find the coolant drain tap? Is it at the bottom of the radiator?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 15 November 2013, 14:53 »
passenger side of the rad down the bottom
