Author Topic: What annoys you about your MK7?  (Read 110575 times)
Offline Andyduz
Re: What annoys you about your MK7?
« Reply #130 on: 27 November 2013, 19:46 »
Love the car and no issues other than intermittent loss of phone connection when dialling/ receiving calls and temperamental door lock with keyless. These are far outweighed by the many positives though.
Delivered 21st Nov. GTD Pure White, Keyless, Winter Pack, Dynaudio, Tel Prep, High Beam Assist, Climate Screen, Discover Nav, Park Assist, Rearview Camera, Voice Activation
Offline MJ-GTI
« Reply #131 on: 28 November 2013, 06:34 »
All these niggles regarding DSG, i haven't driven a car with DSG gearbox before. How would i even know if its working correctly or not?
Current: Mk7 GTI | 5-Door | Pure White | DSG |
Previous: VW Polo 1.6 Comfortline
Offline monkeyhanger
« Reply #132 on: 28 November 2013, 07:53 »
Finally got my handbrake fixed - switch and sensor replacement. The harsh (sometimes reluctant, especially in reverse) release of the autohold is now gone. Maybe I can learn to like the system if it's working properly now.
Offline GrahamFR
« Reply #133 on: 28 November 2013, 09:53 »
Are VW saying this is a recognised fault now then?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
« Reply #134 on: 28 November 2013, 10:35 »
Not sure about “recognised” as a common fault, but they certainly had a fix for it. Prior to the fix I had twice had a complete failure of the autohold/handbrake system with all the textual warnings and symbols popping up on the MFD, getting autohold to let go once reverse was engaged was sometimes impossible, requiring autohold to be switched off. A few times the handbrake didn’t wind on when I parked up at home (luckily it is quite flat), and general autohold release was very harsh. All that is gone now. Are you having the same issues? They apparently replaced a sensor and a switch.
Maybe they didn’t have a fix 2 weeks ago when the dealership simply wiped the fault code from the ECU.
Offline GrahamFR
« Reply #135 on: 28 November 2013, 10:53 »
No mate not yet anyway, i am building a list of things to check for when i go pick mine up next week ish
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline simonpolly
« Reply #136 on: 29 November 2013, 19:17 »
Bloody squeal from the rear of the car when the car is reversed off the drive first thing in the morning, normally when its wet and possibly from the rear brake disc although I am not braking at the time. :undecided:
I get this every day, without fail, regardless of the weather.  And its loud  :angry:
Same here ,have you mentioned it to your dealer? Yours is pretty much the same spec as mine
Golfgti build quality is average at best.
Offline pauliem
« Reply #137 on: 29 November 2013, 19:40 »
Mine creates the same squeal in reverse, normally first thing.  But I don't really care.  :whistle:
Offline simonpolly
« Reply #138 on: 30 November 2013, 17:29 »
you will when the wheel falls off  :whistle:
Offline adey V
« Reply #139 on: 30 November 2013, 18:14 »
Fuel consumption at 28mpg :angry:
GTi PP 3 door DSG, carbon grey, Pan sunroof, ACC, winter pack, keyless, Pro nav. climate windscreen, advance phone prep.
