Author Topic: Replacement Engine!!!  (Read 5584 times)
Offline ab17790
Re: Replacement Engine!!!
« Reply #10 on: 16 November 2013, 08:55 »
I work for Audi and we replace a lot of pistons/rings and it not too much of a big job,it's not worth having a a new engine if you only require piston rings.
It was always on A4/A5 2.0 TFSI oil consumption :)
My Car-2016 Golf 1.0 TSI Match Edition BlueMotion 115PS,17inch Singapore Alloys,Tech Pack,Parking Pack,Rear Camera,Heated Steering Wheel,Winter Pack,90% Window Tints,Front & Rear Mud flaps,Headlight and Boot Protector
Dad-Golf MK7.5 R Estate Pearlescent Black,Reversing Camera
Mum- Golf MK7 GTI PP 5 Door-Manual,White,90% Tints,Rear Camera,Front and Rear Mudflapa,19 Inch Santiago Wheels
Audi Technician
Offline matty246
« Reply #11 on: 16 November 2013, 20:55 »
Thanks - that's really helpful. Is there anyway I can be sure it's the piston rings eg compression test? Before embarking on the job? I'm assuming it's still a big job even if it's less than the replacement engine
Offline matty246
« Reply #12 on: 25 November 2013, 13:56 »
The dealer's Service Manager has said he checked with VW and the oil consumption is within th etolerances of normal (just). He doubts it will ever start to use more oil in the future.
A couple of people have suggested changing to 5w40 which I will do, hoepfully with the blessing of the local dealer. Interestingly when it was first serviced the dealer put a 1 litre top up can in the boot and I swear that was 5w40. Did VW change the spec to 5w30 at some point?
I'm also thinking of getting the dealer to do a compression test when it is serviced (even if I have to pay for this myself)
