Golf mk3
hardmonkeys
Best Way To Stick Arches On My Car
Topic: Best Way To Stick Arches On My Car (Read 4478 times)
Shizzle
13 November 2013, 08:15 »
As title says i have rolled arches so unless i make new holes some how for rivets im not sure how to stick them on 1 has fallen off already but thanks to andyw1986 i have a complete set to replace mine just don't want to lose another
MK3 Golf GTI 2.0 16v 3Door Storm Grey
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: Best Way To Stick Arches On My Car
13 November 2013, 08:22 »
Tiger seal if you don't want to screw or rivet them on.
Shizzle
13 November 2013, 09:30 »
Not that i don't want to have no where to screw to ok will look at getting some tonight the only problem i have is can only fit them out side an the weather never helps with this sort of stuff.
tweed
Forum addict
13 November 2013, 09:34 »
I used no more nails anti vibration. It doesn't go hard so if you still need to flare them once they're you can, as I had to.
I think first time mine came off but I didnt leave it long enough to go off. If it says 24 hours then in this cold weather you want to leave it for 48 hours. Glue them on then use plenty of masking tape to hold them down tightly.
But everyone I know uses tiger seal so what ever is cheapest.
Untitled
by
tweedub
, on Flickr
gasketface
13 November 2013, 09:49 »
I use this,goes off quick in any (dry) weather :-
http://www.ebay.co.uk/itm/WINDSCREEN-GLASS-REPLACEMENT-BONDING-ADHESIVE-GLUE-/370550414951?pt=UK_Body_Shop_Supplies_Paint&hash=item5646869e67
scratch up the inside of the arches first though (criss/cross)
Shizzle
13 November 2013, 10:12 »
Just purchased that seal stuff for windows be doing it Saturday night will cover arches so stay dry and stick on with tape so stay in place thank you for your replies will post pics once dry
CraigBest
Golf Gti Mk3 Colour Concept Flash Red
Reply #6 on:
17 November 2013, 21:05 »
I used double sided sticky pads but that's only a temporary solution until I get a new front wing.
Wayne
Sir Postalot
Reply #7 on:
19 November 2013, 21:46 »
Tiger seal will do the job all ok.
Callum_K
Here all the time
Reply #8 on:
20 November 2013, 09:17 »
If you have a Toolstation near you, get a tube of their PU-40 adhesive, it's a polyurethane based sealant, exactly the same as Tiger Seal etc, but only about £2.50.
danmusic24
Reply #9 on:
20 November 2013, 18:59 »
As above! Grip fill or bluetack
Golf mk3
hardmonkeys
