Author Topic: Heater only blows out cold air.  (Read 7456 times)
Offline D1andonlyantman
« on: 13 November 2013, 03:19 »
Hi. Sorry for making yet another thread but you know what it's like when you get a new car and there are a few problems here and there you're unfamiliar with. I did try and tackle it myself first :)
Anyway, my fans only blow out cold air. It gets a tad warner once the engine is warm but is still clearly cold. Defogging before and after work ( I work shifts ) is a right pain in the arse, not to mention it's starting to get pretty chilly outside. I checked fuses 1, 5, 25 and 26 after reading a list of what they do and thought one of them might be the issue but they all look fine. Has anyone got any sparky ideas as to why it won't come out hot? I'm pretty much positive I'm using the controls right. Fans on, press red button loads till it says 'hi'.
All ideas appreciated.
« Last Edit: 13 November 2013, 17:16 by D1andonlyantman »
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
Offline dom
  • Back in a Mk4
Re: Heater only blows out cold air.
« Reply #1 on: 13 November 2013, 08:24 »
Does the engine reach normal temp on the gauge? Sounds to me like the thermostat is stuck open.
« Reply #2 on: 13 November 2013, 14:01 »
Yeah I think so. Gets up into the 90s if I remember rightly. Is the thermostat easy to check/replace?
Offline mcgee9t2
« Reply #3 on: 13 November 2013, 14:10 »
to check it remove it and place in hot water and see if it opens, if your removing it you might aswell replace it though and then its done. to remove it, drain the rad and coolant system, theres two bolts to undo on the stat housing remove the pipe and pop the stat out, insert new stat and reverse proceedure, theres a guide in the how too.
First time its a right PITA, but as with everything once youve done it once its a breeze the next time, first time it took me a hour and a half in the middle of the day, second time it took me 20 mins at 10pm at night.
« Reply #4 on: 13 November 2013, 14:12 »
Ok cool. Where do you guys get all your little bits like this or is it a eurocarparts jobbie?
Thanks.
Offline mcgee9t2
« Reply #5 on: 13 November 2013, 14:40 »
Most people go VW. think its around £24 for the Stat, + £10 or so for the coolant.
« Reply #6 on: 13 November 2013, 14:42 »
Ok cool. I'm getting an oil change done soon so will get it all done at the same time. Cheers for the heads up.
Offline dom
  • Back in a Mk4
« Reply #7 on: 13 November 2013, 15:54 »
If the gauge hits 90 then it's unlikely to be the stat, it could be the heater matrix :undecided:
« Reply #8 on: 13 November 2013, 16:27 »
That's what I was thinking. If the thermostat was stuck open then wouldn't it constantly be trying to cool with the fan going?
Offline mcgee9t2
« Reply #9 on: 13 November 2013, 16:40 »
ope if the stat was stuck open the water from the radiator would constantly be running around the engine in turn making the engine hardly ever hit 90 degrees.
