Author Topic: handle removal  (Read 1377 times)
nogama3
handle removal
« on: 22 August 2005, 19:30 »
guys, how do you remove the handles on the mk3? i undone the screw at the back but the handle deosn't budge, seems as if there's some hidden screws, any help appreciated.
Offline jte
Re: handle removal
« Reply #1 on: 22 August 2005, 22:21 »
I assume you mean the exterior door handle, if so...
per Bentley manual
1. Remove socket-head screw from side of door (what you have already done i guess)
2. Slide door handle forward and pivot hadle out of door.
NB/ On driver's door, insert key and turn key 1/4 turn before pivoting handle out of door (when the key is turned, door handle carrier releases operating lever)
Hope that helps.
A VR6 isn't a way of life, it's just a car.
