Author Topic: EA288 2.0 TDI 184PS Development thread..  (Read 189988 times)
Offline Agreeable Slick
  • Unit
Re: EA288 2.0 TDI 184PS Development thread..
« Reply #230 on: 11 August 2014, 21:45 »
You need to have made 10 posts before the PM option appears.
That explains why then, thanks
This does not mean you go around the forum spamming topics with "." in order to get your post count up. Make a valid contribution.
Offline Mark mans
« Reply #231 on: 15 August 2014, 18:53 »
Not sure if it was on this thread but had read that people were experiencing problems when starting their car from cold, I.e car would turn over several times before firing up.
I don't have a tuning box fitted and mine has had this problem from day one, so it's not the box causing the problem
Offline Mark mans
« Reply #232 on: 15 August 2014, 18:57 »
Does anyone here have the dtuk box fitted to their GTD with the DSG gear box? If so, any problems with the increase in torque produced from the tuning box?
Have read that the DSG box can only handle upto 450 and not the 500 the tuning box can produce
Thanks
Offline virginVWman
« Reply #233 on: 19 August 2014, 15:11 »
Andrew, what's the difference between the old map and most aggressive (4+1)on the older unit than this new 3+1 on the new unit? As is it worth me sending you my unit to update? Ta
Mk VII 3dr GTD in DBP
Fitted DTUK Stage 2 (CRD-T)
Offline Andrew@DTUK
« Reply #234 on: 19 August 2014, 15:16 »
no difference whatsoever where software is concerned
Are you looking to tune your Golf GTI or GTD? Were currently offering members £80 off the full RRP on all DTUK Petrol and Diesel Tuning Systems.
PM me for the discount code
Offline Mark mans
« Reply #235 on: 20 August 2014, 16:35 »
Have received my crd-t+ box from dtuk, now to go and fit it :)
Offline Bluefloyd
« Reply #236 on: 20 August 2014, 18:17 »
Great. Let us know what you think Mark as I am very interested once I've put a few miles on the clock. How many miles on yours mate?
Black Gtd with box
Offline Mark mans
« Reply #237 on: 20 August 2014, 18:22 »
All fitted, I have set the box to program 3 +1. Is it normal for the lights to flash or should they be permanently on? P3 is flashing green and +1 is flashing red.
Not taken the car out yet for a test run
Offline Mark mans
« Reply #238 on: 20 August 2014, 18:23 »
Will do, it has 5500 on it now so it's well run in
Offline Bluefloyd
« Reply #239 on: 20 August 2014, 18:57 »
http://www.golfgtiforum.co.uk/index.php?topic=266760.msg2472009#msg2472009
Hope this helped but one of the guys who have one will be able to tell you more
« Last Edit: 20 August 2014, 19:00 by Bluefloyd »
Black Gtd with box
