Author Topic: Tyre Size  (Read 7045 times)
Offline hastd2
  • Gti the Ultimate Hot Hatch...
Tyre Size
« on: 11 November 2013, 11:54 »
Guys what tyre size is fitted to the Gti  :undecided:
Am pricing up winters as up in Aberdeenshire we could get a lot of snow coming our way, so am getting ahead of the game and getting my tyres ordered before the mad rush!!!
Build Week 11.04.16 - 2016 Mk7 Golf R, Lapiz Blue 5 door manual, 12 months R/Tax, 2 yrs free service, full tank of fuel, sure guard, and private plate transfer
2015 Mk7 Gti 5 DR, Carbon Steel Grey, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
2013 Mk7 Gti 5 DR, Pure White, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
Offline Gingernick
Re: Tyre Size
« Reply #1 on: 11 November 2013, 12:30 »
225/40 18's
though a winter tyre will have a different profile I am guessing
I know I was toying with the idea of the 19's but is quite a jump in tyre cost..and when I had my octavia vrs front tyre changes were an annual event!
would the performance pack differential aid in cold weather driving do you think?
« Last Edit: 11 November 2013, 12:34 by Gingernick »
3dr Gti, manual, tornado red, performance pack, dynaudio. gone now
5dr GTi, manual, red, Performance pack, dynaudio
going
5dr Gti, Manual, performance pack , indium grey (for a change!)
Offline dubber36
Re: Tyre Size
« Reply #2 on: 11 November 2013, 12:57 »
225/40 18's
If you are changing to winter tyres on the original wheels, the sizes must remain the same to retain the overall rolling radius. Many people have a second, smaller set of wheels, so going down to a 17" wheels would mean 225-45-17 or 205-50-17, or 16" wheel (subject to brake clearance) would be 205-55-16.
Offline GTI-7-Performance
Re: Tyre Size
« Reply #3 on: 11 November 2013, 13:41 »
There is a lot of debate and opinion on the internet about the width of winter tyres. The standard summer wheels (Austin) are 7.5J (width) x 18" (diameter of the wheels without tyres). The tyres are  225 x 40 (40 is the wall height in mm).
The Swiss VW option for winter tyres is 17" Dijon wheels with 205/50 R V XL Pirelli Sottozero tyres. We can get winter wheels that are 19" and 8J, but the debate comes with theories on whether a wide tyre can grip in snow as well as a narrower on and whether the are more prone the aquaplaning.
But the overall diameter of the complete wheels is about the same whatever size wheels are chosen - summer or winter. The GTi with Performance Pack can't take smaller than 17" due to the larger brake assembly...
Offline Gingernick
Re: Tyre Size
« Reply #4 on: 11 November 2013, 13:43 »
will 17's fit over the bigger brakes of a performance pack car?
going
Offline mcmaddy
Re: Tyre Size
« Reply #5 on: 11 November 2013, 13:46 »
yes just.
Offline dubber36
Re: Tyre Size
« Reply #6 on: 11 November 2013, 14:05 »
No it's not. The 40 is the aspect ratio, which is a percentage of the width of the tyre. In this case, 40%
In this country winter tyres are more to do with cold weather performance more than dealing with snow and ice. My theory is more of the correct compound in contact with the road is better most of the time. When racing cars have wets fitted, the size of the tyre stays the same, it's the compound and tread pattern that changes.
Offline Geomets
Re: Tyre Size
« Reply #7 on: 11 November 2013, 14:53 »
I'm quite sure the 40 is the percentage of the tyre width and not the height in mm. Just measure them and you'll find out :smiley:
Re: Tyre Size
« Reply #8 on: 11 November 2013, 15:38 »
:embarrassed: Yes of course you are right...
Offline Spenaldo
  • CSG GTI
Re: Tyre Size
« Reply #9 on: 11 November 2013, 18:46 »
I have just ordered a set of 16" steel wheels and with 205/55/16 wheels, you can get either the 6J or 6.5J, both will fit onto the standard GTI or GTD.
I'm based in Germany and we are required to get the correct tyres for the road conditions, in all a full set with Hankook icept rs tyres cost €418 including fitting.
Interestingly I could have had a set of 18" winter tyres fitted to the OEM rims, for €386 but decided against it due to the amount of snow we usually get. Plus the rims would get rather pitted in the winter, I will post some fots once fitted at the end of the week.
