Author Topic: Exhaust help - Reducer/Sleeve Question?  (Read 2776 times)
Offline GOLF-MK3-GTI
« on: 08 November 2013, 15:16 »
So i own  a Golf MK3 GTI 8V. I have an Jetex Exahust which was removed from a MK3 16V. Bought it off Khare.
Am i right in thinking that the standard exhaust size on the 8V were 2" (50MM) and on the 16V they were 2.5" (55MM).
The question is, i need a reducer/sleeve to mount the 2.5" exhaust on the 2". How long should the reducer/sleeve pipe itself be?
Thanks.  :wink:
Offline boneybradley
  • Back in a Mk3...
Re: Exhaust help - Reducer/Sleeve Question?
« Reply #1 on: 08 November 2013, 15:49 »
if it's cat back it will slot straight on (both outlet's from the cat are 55mm)
« Reply #2 on: 08 November 2013, 16:00 »
Yes it's cat back. Thanks for the info boney.  :cool:
Offline Foreveryoungaus16v
« Reply #3 on: 08 November 2013, 19:32 »
I was thinking of buying that. But I came to the conclusion that for an extra £160 I would rather get a brand new one with fitting.
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #4 on: 08 November 2013, 20:00 »
2.5" is not 55mm :wink:
« Reply #5 on: 08 November 2013, 20:05 »
Damn, it's 63.5mm  :embarrassed:
« Reply #6 on: 08 November 2013, 20:06 »
True, but it'll do  :grin:
« Reply #7 on: 08 November 2013, 20:18 »
For sure, it's a good bit of kit
Offline xionsolaris
« Reply #8 on: 09 November 2013, 21:52 »
Does the exhaust have the middle mounts on the mid silencer my stainless steel one I bought had this and it wouldn't fit my 8v
« Reply #9 on: 09 November 2013, 23:42 »
I'll have to check, but from memory I think no, it hasn't got middle mounts on middle box.
