Author Topic: keyfob battery  (Read 1961 times)
Offline navmk4gti
keyfob battery
« on: 07 November 2013, 12:25 »
Anyone know the size of  the mk4 keyfob battery? I have no battery in my spare key . Looks like them batterys you find in watches i think :smiley:
Offline Tezmax
Re: keyfob battery
« Reply #1 on: 07 November 2013, 16:25 »
Maxell CR2032 H 3v
Hitatchi Maxell Ltd Japan.
Hope that helps!!
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline navmk4gti
Re: keyfob battery
« Reply #2 on: 07 November 2013, 16:34 »
Wikid thanks  :smiley:
Offline bullzeye
Re: keyfob battery
« Reply #3 on: 16 January 2014, 15:31 »
Just bought 2 didnt fit ; (
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline navmk4gti
Re: keyfob battery
« Reply #4 on: 16 January 2014, 16:15 »
I stil aint fitted ones i got :lipsrsealed: ill check when get home mate.. if they fit ill send you the link
Offline bullzeye
Re: keyfob battery
« Reply #5 on: 16 January 2014, 17:19 »
Guy at corner shop said I need 16 20 or somet need to know what to order cos they take 2 batteries each so I need 4
Thanks pal
Mrs bullzeye
Offline Scott D
Re: keyfob battery
« Reply #6 on: 16 January 2014, 19:31 »
CR2032
100% the battery size needed
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline bullzeye
Re: keyfob battery
« Reply #7 on: 17 January 2014, 09:29 »
That's what I bought Panasonic 2032 3v and there about 4mm too big
Offline Dalo Harkin
Re: keyfob battery
« Reply #8 on: 17 January 2014, 10:37 »
aren't there 2 different typed of MK4 fobs  :huh:
Offline mcgee9t2
Re: keyfob battery
« Reply #9 on: 17 January 2014, 12:35 »
2 batterys in each fob? this may be why i cant get my fob to work :D
