Author Topic: Golf mk2 starts fine but when turned off, wont re-start again?  (Read 3199 times)
Offline lanceh_09
  • VW Freaks On Facebook Search 'VW Freaks Official'
1986 Golf Gti 8v
Hi folks, straight to it! If i go out to the car now it will fire up and run fine. If i leave it running for a couple of minutes and turn off it will fire again no probs but.. If i leave it running for say 20-30 mins switch off then try and fire again... Nothing just cranks and cranks but no fire! Yet if i leave it say 2-3hrs it fires up again first time!
With a little more detail on first fire, it cranks for 5-6secs then go silent like somethings stook in compression, cranks again for 5-6secs silent again.. then fires?
Thanks lance
Visit VW Freaks on Facebook by searching VW Freaks Official
www.facebook.com/vwfreaksofficial
Offline Sgt_Lemon
  • 8v owners club
Re: Golf mk2 starts fine but when turned off, wont re-start again?
« Reply #1 on: 06 November 2013, 17:20 »
Is the engine overheating atall, is the fan coming on?
Offline lanceh_09
« Reply #2 on: 06 November 2013, 18:13 »
Ye the fan kicks in when needed an its aroumd that time that if i kill the engine then try to re-fire it doesnt wanna go!
Offline Dolly
« Reply #3 on: 06 November 2013, 18:25 »
my 85 gti doesnt like it when its hot either, pretty sure its something to do with the fuel air mix, seems to flood instantly, it goes if i remember to get on the loud pedal before i turn the key  :laugh:
Offline lanceh_09
« Reply #4 on: 06 November 2013, 18:44 »
Ye its Strange! No idea why it doesnt like being warm? Want to know why it pauses like battery flat before start up too? Wanting to get it done as we moving house and im wanting to drive it instead of towing! :)
Offline Retrocool
« Reply #5 on: 06 November 2013, 18:50 »
Could it be the starter motor?  Mine was doing this a while back, gradually got worse until it wouldn't start at all. Swapped the starter and it fires 1st time every time now.  (for a time I just carried a hammer and hit the starter until the thing started  :tongue:)
Offline dubber36
« Reply #6 on: 06 November 2013, 21:09 »
Probably totally unrelated, but mine used to do this and I may have fixed it by accident when the fuel gauge stopped working. The plug on the sender unit on the top of the tank, accessed by the round hole in the boot floor was loose. Since plugging it back in, it's started on the button every time.  :huh:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #7 on: 07 November 2013, 03:05 »
May seem odd, but i'd try another battery to start with, or at least get it tested
Thom
Offline oakgreener
« Reply #8 on: 07 November 2013, 10:18 »
How old are your plugs? Wouldn't hurt to try a new set anyway
Offline Shizzle
« Reply #9 on: 07 November 2013, 10:54 »
My MK3 Did the same thing and in the end would not start again and it was down to crank sensor and when plugged in showed no faults.
I broke down and it would not start when waiting for AA  2 hours later he arrived and it started 1st time then shortly cut out i changed crank sensor and it worked fine this may not be your problem but worse case you could try this.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
