Author Topic: 17963 on-going problem!  (Read 2869 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 05 November 2013, 14:46 »
Hi everyone, it has been a while since I have been on the forum, but I have since re-caught the modification bug and have had a wellycooler FMIC, deleted the carbon canister and had a custom made full turbo back exhaust with a 2 & 1/2 inch down pipe and 200 cell sports cat (which sounds awesome).
anyway, the ideas for doing these mods have been born from trying to get my remapped car feeling remapped again. I have consistently had the  code "17963/P1555 - Boost Pressure Control: Upper Limit Exceeded" over the past year or so keep popping up. This results in the car going into limp mode when putting my foot down, I can feel it hold back, then sometimes the power suddenly comes back.
I have an AUM, you can see what other mods I have in my signature (quite a lot), there are no boost leaks in the silicone pipes, as all have been changed except for the hard plastic bit with the grey cover that goes to the actuator. The actuator is set at 2 turns and a bit of pre-load. I have tried 3 turns and 1 & 1/2 turns. None of which make much difference.
Possible reasons?
1. I still have the N112 valve hooked up, could this be the cause of the code and going into limp mode if it is not working properly?
2. N75 valve. I originally had a C valve, I replaced it with an E valve from TPS. The other day I put the old C valve back on and after 2 days the code came back and made the MIL show up on my dash. Before now the MIL light wouldn't show up, but the code would still be there. Could both N75 valves be at fault? I am not sure if the E valve is the right one for my car because the original was a C. Should it be the F valve I use?
R-Tech suggested to me it was the N75, but also suggested I ask on the forum as it sounds a bit puzzling if its not the N75 valve. So I am asking what people think, especially about the N75 valve, or if they have another idea what could be causing this problem. I really need to sort this because I want to go stage 2 with R-Tech.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline GTi_James
Re: 17963 on-going problem!
« Reply #1 on: 10 November 2013, 20:37 »
Contact forge and get the repair kit for your DV and also have a look at your actuator and possibly replacing that?
« Reply #2 on: 10 November 2013, 21:01 »
I have done both of these things not that long ago, I got the Forge actuator with yellow spring.
Update on the problem. I replaced the N75 valve and now the code seems to of gone, but has been replaced with the infamous 17705 code!
Offline D1andonlyantman
« Reply #3 on: 11 November 2013, 01:58 »
Slightly off topic but where did you get your exhaust and how much was it? I'm thinking about possibly doing the same.
Thanks
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
« Reply #4 on: 11 November 2013, 09:25 »
Thanks
From here http://www.topgear.co.uk/ I paid £750 for a 2 and a half inch down pipe turbo back, 200 cell sports cat and cat back complete system with a life long guarantee
Offline Nino
« Reply #5 on: 11 November 2013, 09:33 »
You wont have the 17705 code unless you have a boost leak, on saying that the AUM is known for this as a "Ghost" code.
When was the last time you check your injector seats/seals?
I might also be worth checking your rocker cover gasget and inlet manifold gasget too.
Current - MK6 GTi Edition 35 - Candy White - 3 door
« Reply #6 on: 11 November 2013, 09:52 »
Only a little while ago I sprayed some stuff on the injector seals and I couldn't see anything that suggested a leak.
Will the car be put into limp mode with the ghost code?
Where is the rocker cover gasket and inlet manifold gasket?
Thanks
Offline Nino
« Reply #7 on: 11 November 2013, 11:26 »
Thanks
If its a ghost code then no.
The rocker cover gasket and inlet manifold gasket are located exactly under the rocker and inlet manifold dont cost alot to change and an easy DIY job too :)
« Reply #8 on: 11 November 2013, 15:16 »
Thank you!
I will go and have a look for a diy guide on it  :smiley:
« Reply #9 on: 11 November 2013, 15:19 »
I think I'm going to get one of their customs. Cheers for the heads up :)
