Author Topic: car non starting (solution)  (Read 1350 times)
Offline djmagpie
« on: 05 November 2013, 00:02 »
if this is in the wrong section pls move ,,,my car has been really struggling to start from cold for about 2 weeks just cranking and having to keep pumping the pedal for about 3 mins or so it would start but missing and revs on idiail were all over the place and really poor mpg well yesterday it wouldent start at all , I solved this by replacing the crankcase sensor now everything is fine starts first time ,,wanted to buy gen but they wanted £138 but got one from gsf for £27 hope this helps someone with the same problem
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline sharki786
  • GOT BOOST??
Re: car non starting (solution)
« Reply #1 on: 05 November 2013, 09:50 »
Im having same problem with my mk3 gti. I replaced the battery with a brand new one (yuasa 500) it has 550 cca. Now i get full power to starter but still taking ages to fire. Going to have a look at the crank sensor.
 :smiley:
*****MK3 Anniversary*****
*****MK4 GTI T*****
