Author Topic: Slamming my mk4  (Read 2096 times)
Offline Carl18T
Slamming my mk4
« on: 04 November 2013, 09:56 »
Here's a good one for you all!  I've dropped my mk4 as low as I can go and it's looking loads better, I've fitted a whiteline ARB which has sorted the problem with drive shaft rubbing. If I don't fit spacers the tyres rub on the adjusters if I fit spacers the tyres rub on the arches when I hit a dip in the road or cornering hard. I've had the spacers machined down a little but don't want to go much further or I might touch the adjusters again. Has anyone got any idea on what size spacers to fit. I'm running on 18s with 40 profile tyres. I've messed and messed to get it right but struggling. I can take a little more of the spacers before the tyres touch the adjusters. Also need to get the rears machined down a touch. It's the old problem that mk4s don't sit centered on the chassis. The passenger side is fine by the way. Any help would be great! Thanks
Offline Rhyso
Re: Slamming my mk4
« Reply #1 on: 04 November 2013, 10:00 »
Helps if you tell us what width and offset your wheels are  :wink:
Offline Carl18T
Re: Slamming my mk4
« Reply #2 on: 04 November 2013, 10:52 »
I'm taking them off today so will give more details shortly. Thanks Rhyso
Offline Carl18T
Re: Slamming my mk4
« Reply #3 on: 04 November 2013, 11:00 »
Wheels are 18x8.5j ET:38 what ever that bit means? Hope this helps. Cheers
Offline Carl18T
Re: Slamming my mk4
« Reply #4 on: 04 November 2013, 11:27 »
225 40 tyres with a little amount of stretch. It's more the inner arch that's touching at times.
Offline Nino
  • Insta - F6UGA
Re: Slamming my mk4
« Reply #5 on: 04 November 2013, 12:19 »
My fronts are 8.5j and i had to run 215/40 tyres
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline mcgee9t2
Re: Slamming my mk4
« Reply #6 on: 04 November 2013, 12:40 »
run a bit of stretch on the tyres, get the arches rolled.
Offline Carl18T
Re: Slamming my mk4
« Reply #7 on: 04 November 2013, 12:48 »
Sound. Anyone know where I can get the arches rolled in the stoke area? Not sure if psi tuning do it or if they send them out to be done.
