Author Topic: Bluetooth Audio iPhone 5  (Read 2668 times)
Offline Hawaii-Five-O
  • Are we nearly there yet?
« on: 03 November 2013, 09:18 »
I can't work out why my iPhone 5 won't play audio through the composition media system.
I've followed the instructions in the manual but it simply won't see, or play any of the music (Phone is paired with the system for calls and all contacts work fine)
Anybody else having trouble with the iPhone 5 and BT Audio?
Thx
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
Offline Sootchucker
Re: Bluetooth Audio iPhone 5
« Reply #1 on: 03 November 2013, 16:27 »
5-0, when you go into the bluetooth advance settings, and looks up the profiles under the paired phones, it should have an a couple of profiles next to your phone. One will be "HFP" (which is the phone part) and one should be "A2VDP" (or some acronym like that). Check to make sure you have the second one activated, as if it isn't, you won't be able to stream music over bluetooth.
Worth a check ?
« Reply #2 on: 03 November 2013, 20:35 »
Worth a check ?
Yes I had A2VDP checked :smiley: but still not much joy.
The only way I've managed to get music to play with BT Audio is to go into the music player on the iPhone 5 and hit play. However the only thing you can control via the media system itself is pause. It will not skip forward or backward, it won't let you select other artists. It's bobbins.
Can somebody else check - just in case it's me being thick :wink:
Offline pauliem
« Reply #3 on: 06 November 2013, 09:15 »
I didn't do anything to mine to make BT Audio work, it just did.
However, I cannot go back a track, only forwards and there is no track listing.  Overall it is not brilliant.
