Author Topic: golf mk3 on montreal 2?  (Read 4109 times)
Offline hotdogsmale
  • You just cant go wrong with a golf!
« on: 02 November 2013, 23:51 »
Anyone had problems with them?
Offline boneybradley
  • Back in a Mk3...
Re: golf mk3 on montreal 2?
« Reply #1 on: 03 November 2013, 16:10 »
you need spacers on the back to clear the centre cap vs bearing dome cap otherwise direct fit
VW BUSH
« Reply #2 on: 03 November 2013, 20:09 »
What Boney said or mod the centre caps with a hammer if possible + Mk4 tyre profile looks gash on a Mk3 and may rub if your low also will put your speedo out. Need to compensate for 16" rim with your tyre choice :smiley:
« Reply #3 on: 03 November 2013, 21:00 »
You will need to switch the tyres to 205/45/16's but they do llok good on a mk3.
Offline andy_k
« Reply #4 on: 03 November 2013, 22:25 »
215/40/16s look nicer :)
Offline hotdogsmale
« Reply #5 on: 03 November 2013, 23:08 »
Ok guys thanks :) im standard hight atm but will change tyres in the future what size you guys think?
« Reply #6 on: 03 November 2013, 23:38 »
195/45/16 or 205/45/16 are good choices also 215/40/16 which was standard size on the Anni's
Offline hotdogsmale
« Reply #7 on: 11 November 2013, 21:15 »
What size spacers do I need? Cheers
  • Back in a Mk3...
« Reply #8 on: 12 November 2013, 12:41 »
I believe about 6mm (3mm a side) although you can go up to 12mm (6mm a side for better looks)
Offline andy_k
« Reply #9 on: 13 November 2013, 00:14 »
Unless you know somebody that has fitted this wheel/tyre combination you need to do a bit of measuring. Offer the wheel up and see where it catches/rubs then make some temporary spacers (washers etc from a DIY store) and find out how far you have to go before everything rotates smoothly.
It's best doing stuff like this with new pads in the front as the caliper may move outwards when you fit new ones.
