Author Topic: Gutted !  (Read 5278 times)
Offline Ric28
Gutted !
« on: 01 November 2013, 20:25 »
Hello people ,
I have just taken my new ( to me ) 06 golf gti out for a spin .  I put my foot down and went thru the gears and it went well and quick but then when I hit 5 th gear it just died and there was nothing there .  I slowed down and carried on slower and it was fine .  Next time I put my foot down it went to 5th awesome and then died again , I free wheeled and then it came back.
I have searched and read and most point to the coil pack . Does this sound like a problem anyone else has had ?  It seems to drive steady fine but nail it and hit 5th and it misses.
I am a little gutted that I have this problem on the first day on the road.
Any help appreciated
Offline barrym381
Re: Gutted !
« Reply #1 on: 01 November 2013, 21:00 »
they had a recall on coil packs so its worth checking with vw they have been done  :wink: not saying that is your problem though
Offline Ric28
Re: Gutted !
« Reply #2 on: 01 November 2013, 22:03 »
Yeah I I am gonna call my local vw dealer in the morning .  I have a sticker under the boot mat tho so I think they have already been done but worth a call .
I hope it's coil packs and I don't have an ongoing problem like I am reading on here a lot .
Offline dTEA
  • back in an MK5
Re: Gutted !
« Reply #3 on: 01 November 2013, 22:52 »
Is it DSG or manual?  Is it only 5th? and is it always within a set rev range? or is it present throughout the gears to a lesser extent at a set rev range?
Edition 30 / T5 T32 Kombi
Offline Ric28
Re: Gutted !
« Reply #4 on: 07 November 2013, 19:49 »
Hi guys just giving an update on my problem .  The car had already had coil packs replaced under the recall in 2011 but I have just had it fully serviced , plugs and new coil packs , took it for a blaze tonight and nailed it through to 5 th and boom ! Died , no throttle response at all .  Free wheeled for 10 seconds and it came back .  When it did it again in 6 th I dropped into 5 th and nothing , free wheel for a few seconds and it comes back .
It drives spot on steady but once foot hits the floor it doesn't like it .  My mechanic also checked the cam follower and said all is ok .  I am thinking sensor of some kind but this problem seems to be happening a hell of a lot so surely someone has experienced and solved this problem ,
Offline Ric28
Re: Gutted !
« Reply #5 on: 07 November 2013, 19:51 »
It's manual aswell .  Seems to be at high revs and not every time but most times I drive it hard
Offline bacillus
Re: Gutted !
« Reply #6 on: 07 November 2013, 23:14 »
Get it scanned if not already done so.
My guess is you have an issue with your throttle body's sensor.
Without traction power is nothing!
Offline Ric28
Re: Gutted !
« Reply #7 on: 10 November 2013, 14:33 »
Came up with code p2293 which is fuel pressure regulator 2 performance .  I am going to try cam follower and thrust sensor and if that fails I will try low pressure fuel pump and then hpfp .  Hopefully this cheaper attempt will work
Offline George k
Re: Gutted !
« Reply #8 on: 10 November 2013, 15:06 »
May be camshaft worn and not just follower. Worth a look while pump and follower are out
Offline Ric28
Re: Gutted !
« Reply #9 on: 10 November 2013, 15:37 »
Would it be obvious to see if the camshaft was also worn? You would think if the follower was ok the camshaft should be unless the previous owner has fitted a new follower onto a bad shaft .
