Author Topic: tweaking the bluefin... what's that about?  (Read 5137 times)
Offline mkviken
Re: tweaking the bluefin... what's that about?
« Reply #10 on: 02 November 2013, 21:39 »
my flat spot was caused by demanding too much boost so on a neutral throttle at certain rpms the car didn't like it and hesitated
they sent me a map with reduced boost between 2800rpm-3000rpm and it solved it
it had nothing to to do with the wrong map being sent for my car
my flat spot was only noticeable on a light acceleration from a neutral throttle over a band of around 200 rpm and only happened rarely
with the new map it was spot on
Golf GTI 7.5 230 white silver
« Reply #11 on: 03 November 2013, 12:18 »
I would think (hope) that Superchips would run their guinea pig car on the rollers and do some live data mapping on the open road and the generic sale Bluefin map would be a 'best average' map that was fairly safe for clutches and other components.
They would then have several other maps and loads of data from the test runs that would allow them to adjust boost and ignition amongst other settings for customers that reported problems.
I've had remaps altered in the past on a TDI where I experienced clutch slip in the higher gears. A quick change or the torque graph to make it less spiky and hey presto, the clutch never slipped again and the car was near as dammit just as quick.
Particularly as cars get older and components wear you're bound to get variations in how cars respond to maps so a generic remapper will have several files available as it's not practical for them to examine every single vehicle they come across.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #12 on: 04 November 2013, 09:03 »
Did you ever get round to having the car rolling roaded as I always wondered what the difference the map on yours made compared to stock on paper?
Current Garage:
35+ years of GTI ownership.
