Author Topic: heater  (Read 1622 times)
Offline gibbogti
heater
« on: 31 October 2013, 21:14 »
hi got a 91  8v the heater is really noisey, it works hot and cold but loud any advice on what it could be thanks gary
Offline dragonfly
Re: heater
« Reply #1 on: 31 October 2013, 21:33 »
Best thing to do it remove the motor.  First remove the passenger side tray and the foam cover.  Now lying on your back you should see the motor in the upper right of the dash. You will notice a tab which you need to lift and turn the motor. Disconnect the electrical connector.  You can dismantle it a bit more by pressing the 3 rubber tabs on the casing back to withdraw the motor from its plastic housing. Spray with lithium grease and then re-assemble.
« Last Edit: 31 October 2013, 21:39 by dragonfly »
Offline gibbogti
Re: heater
« Reply #2 on: 31 October 2013, 22:00 »
cheers for the reply will have a look tomorrow thanks gary
