Author Topic: MK4 Golf starter motor connection problems help !  (Read 1968 times)
Offline JOSHJY
« on: 30 October 2013, 10:13 »
Hi everyone
I’ve Recently bought a 1998 MK 4 golf Gti 1.8 petrol
The seller had mentioned that where as he had changed the starter motor recently the earth cable between battery and starter was never changed and seems slightly faulty
Therefore the car occasionally wouldn’t start due to a loss of connection
(why you would change the starter and not the cables at the same time is beyond me but there we are )
The suggested temporary fix he had was to simply “wiggle” the cable apparently restoring the connection and allowing the motor to start
Ive had the car about 6 weeks and had to do this about 5 or 6 times to get it to start as i haven’t had the time to get it fixed , (a pain but for what i paid for the car i can live with it )
However this morning when i went to start it up for work i had nothing even after giving the cable a nudge a few times nothing
Whether this was to do with the fact that it was a slightly colder morning than usual or the cable really is on its last legs now i don’t know ?
Anyway after panicking i was going to miss my train i managed to get catch a neighbour on their way out and got them to play with the cable whilst i switched ignition on and off
Finally it fired up and off i went
The problem i have now is that the car is parked in the station and im worried when i get back im going to have the same issue and get stuck
Does anyone know if theres a better temp solution to get it to start than just wiggling the cable?
obviously i don’t have any tools with me in work..... but would perhaps electrical tape securing each connection point work?
Also is changing this cable a fairly easy job? From what i can see it just seems like 2 bolts between the battery and starter?
Providing i can find a cable from the scrappy on Saturday i would be pretty tempted to try and change it myself
Josh
Offline Luke1981
Re: MK4 Golf starter motor connection problems help !
« Reply #1 on: 30 October 2013, 10:20 »
I think you have just answered your own question. Replace the cable.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Shizzle
« Reply #2 on: 30 October 2013, 10:25 »
there isn't really a temporary fix alot of current goes through that cable need a permanent fix and fast  :tongue:
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline xxChrisxx
« Reply #3 on: 30 October 2013, 10:30 »
Take it off, clean the connections, rebolt it up.
Its a huge bit of copper so it shouldnt ever need replacing, as its petty difficult to damage them. Even if you do a new 170amp cable is cheap.
Offline JOSHJY
« Reply #4 on: 30 October 2013, 11:01 »
i know i should have sorted it out when i bought it but to be honest it hasn’t been top of my priorities
Problem is now earliest I’m going to be able to change it now is Saturday
And i need the car at least for tomorrow and Friday
Thanks Chris il give that a go when i get home wondering now if then perhaps it isn’t damaged and it perhaps just dirty/unsecured
Im assuming getting hold of a new cable shouldn’t be too much hard work, again is changing it then a simple job?
thanks
Offline mcgee9t2
« Reply #5 on: 30 October 2013, 12:48 »
if you have a set of jump leads, put the jump lead on the motor as another cable. start it then see if you can remove the jump lead... wuold recomend driving with the jump lead on the motor incase it comes off.
Offline xxChrisxx
« Reply #6 on: 30 October 2013, 15:15 »
thanks
You have to take them off to clean the connections anyway. What you do is take the cable off, sand the crap off the connections and rub down with degreaser/contact cleaner.
I suppose the question we should have asked earlier is which cable you are wiggling? Is it the power to the starter or the ignition.
If you are truly stuck somewhere you can always bump start the car.
Offline JOSHJY
« Reply #7 on: 30 October 2013, 16:01 »
right great will give that a go asap !
its that fairly thick black cable about "10" long going from battery to starter thats as best i can describe it
thanks for the jump cables tip aswell !
one last thing ( sorry to be a pain )
could anyone hook me up with a link on ebay to the correct lead i need to buy
i think its a 170amp one but not certain what size i need out of these selections
http://www.ebay.co.uk/itm/UK-SELLER-18-EARTH-STRAP-BATTERY-STARTER-CABLE-SOLENOID-CAR-MOTOR-LEAD-BOAT-Etc-/290905307250?var=590122901181&_trksid=p2054897.l4276#ht_1068wt_1411
am i on the right track ?
cheers
Offline mcgee9t2
« Reply #8 on: 30 October 2013, 23:01 »
If buying new I'd just go to vw. Can't see it being expensive and atleast you know it's the correct rating and length.
