Golf mk3
hardmonkeys
Fog Light wires/Door. info needed
Topic: Fog Light wires/Door. info needed (Read 3997 times)
madman2
Re: Fog Light wires/Door. info needed
Reply #10 on:
29 November 2013, 22:34 »
so, I put a male spade connector through the back of that block, the only thing is I have a piece of colored plastic in the way, It seems as though my gti didn't come with fogs so I was thinking will the mean that ill have to put a relay in place?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Reply #11 on:
29 November 2013, 22:52 »
yeah there is a plastic ferrule in there to seal the connector.
forgot about that
no relay needed, the ones with factory fitted fogs didn't have any either.... all done in the light switch (quite possible there are some in there, be it micro relays or transistors)
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Reply #12 on:
30 November 2013, 08:46 »
All seems like a lot of faffing around to save £15 and 10 minutes installing the proper foglight equipped headlight loom.
itavaltalainen
Reply #13 on:
30 November 2013, 16:25 »
why change the whole loom? if you have it yes but why buy one if all you need is one wire from the connector that you can easily retrofit.
it took me under 15 minutes to do the wiring, all you need from main loom is one wire, GND is easy to wire to battery.
Golf mk3
hardmonkeys
