Author Topic: Key fob pcb  (Read 1352 times)
Offline houston
Key fob pcb
« on: 29 October 2013, 10:01 »
I've managed to break my key, the push button has snapped off the pcb. Does anyone know where I can get another one? Does it need a pro to reprogram it or is it just the key in door trick? Been looking on eBay and all I can find is the cover. It's the early 2 button version
Offline mcgee9t2
Re: Key fob pcb
« Reply #1 on: 29 October 2013, 11:26 »
not sure where to get one from. but iirc you can recode them via vagcom. sure someone will do itfor a few beer tokens
Offline dom
  • Back in a Mk4
Re: Key fob pcb
« Reply #2 on: 29 October 2013, 19:27 »
If it's just a broken button you can order a cheap replacement from eBay and swap the broken half over so you keep your blade and immobiliser chip, no need to recode anything :wink:
Offline houston
Re: Key fob pcb
« Reply #3 on: 03 November 2013, 08:24 »
It's the micro switch on the board that has snapped it's pins, prob off the Bairn throwing the keys on the floor all the time
Found a seller on eBay that sells the parts so gonna attempt a fix
