Author Topic: 70 amp alternator upgrade  (Read 2436 times)
Offline sharki786
  • GOT BOOST??
« on: 28 October 2013, 16:42 »
As some may know i am having problems starting the car in the cold. Anyway i have a 90amp alternator sat here. What i want to know will the 90amp fit stratight onto the 70amp alternator braket? Reason due to upgrade is because im running a few upgrades in the car.
P.s engine is AGG Gti anniversary
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline boneybradley
  • Back in a Mk3...
Re: 70 amp alternator upgrade
« Reply #1 on: 28 October 2013, 17:03 »
they do a 70,90 and 120a alty that will be a direct fit (mines on a 90a). I use a co called autoelectro where you can check fitment/call them to ensure
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 28 October 2013, 17:36 »
I need to put the alternator next to it and see if it will fit onto the braket.
Thanks for that boney
*****MK4 GTI T*****
Offline itavaltalainen
« Reply #3 on: 28 October 2013, 17:42 »
It the 90A alternator is from a mk3 golf petrol it will fit - straight swap, unbolt old one, fit new one, job done.
120A has a different setup, for that you'd need to swap the mount as well.
Depending on how old that 90A is you might wanna fit a new voltage reg. They are only 15£ and you can have a look at contact surface on the shaft as well.
Offline vwscottie
« Reply #4 on: 28 October 2013, 19:07 »
If the alternator is one of a car with a/c it wont fit
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 28 October 2013, 19:13 »
The alt i have at home came from a mk3 that had ac but i only have the alt no bracket.
*****MK4 GTI T*****
