Author Topic: injector seals???  (Read 4107 times)
Offline tonysgti
injector seals???
« on: 27 October 2013, 19:15 »
i am gonna be fitting some yellow calibra injectors in a couple of weeks when i replace the seals on them can i just use new ones from vw or standard agu injectors, or do i need to go vauxhall and get them from there?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline WadGTI
  • Golf GTI'er
Re: injector seals???
« Reply #2 on: 29 November 2013, 13:07 »
Just to raise this thread from the dead.
I need to do mines over xmas. Ordered inlet/TB gasket from VW. Does the ebay kit have the seats? or is it the same thing as the seals?
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 29 November 2013, 14:21 »
seats fit into the inlet, seals are on the injector itself
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 29 November 2013, 14:53 »
Is it best to replace the seats? Not too sure if they will be brittle coming out (125k miles on it).
I asked VW about seats over the phone and they said they have horseshow clips which they thought were the seats. I don't think the clips were the seats?...anyways I ordered 4 clips.
Offline rfn_hodgson
« Reply #5 on: 29 November 2013, 14:53 »
We're do you get injector SEATS from??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 29 November 2013, 15:27 »
seats can weep (you get a nice black mark on your inlet around them)
They are available from the dealers, the small and large port are different
The clips they are talking about hold the injector to the fuel rail. There are 8 O rings per injector (4off for the rail connection and 4off to push into the seats) 4 seats (1 per injector) and 4 clips
I'll have a look on ETKA and see what the part numbers are
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 29 November 2013, 15:37 »
AGU injector seats - 058 133 555
AUM injector seats - 06B 133 555 B
O rings are the same for AUM and AGU - 035 906 149 A
WadGTI - did you order 035 906 037?
Offline WadGTI
  • Golf GTI'er
« Reply #8 on: 02 December 2013, 14:02 »
So if I have this right -
Seal - Injector - Seal  - Injector Seat (x4)
AUM injector seats - 06B 133 555 B - Contacted VW (who couldnt find the part no) - Contacted TPS - They say the part is no longer made. However, when I give them my reg and engine code (AUQ) - they say there is no seat listed for it what so ever. I thought the AUM and AUQ and more or less the same engine with the boost turned up? Surley it must have a seat for the injector.
O rings are the same for AUM and AGU - 035 906 149 A  - I will check ebay tonight - VW want £5+ for a seal which is a rip off.
WadGTI - did you order 035 906 037? - Yeah, I think these are the horseshoe clips. Ordered 4  :wink:
Thanks Wazzzer.
« Last Edit: 02 December 2013, 14:09 by WadGTI »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 02 December 2013, 17:21 »
My parts catalogue is a little out of date so they may well have been superseded by another part, but TPS should have it listed on their system.
There is definitely an injector seat, they're just being dumb lol
