Author Topic: turbo silencer removal?  (Read 2043 times)
Offline rfn_hodgson
« on: 27 October 2013, 19:11 »
hey guys how do you remove the silencer from the turbo on the k03s?
only reason why I say this is because ever since I fitted the s3 chrge pipe I I cant hear the turbo any more as the charge pipe has a silencer on it
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline rfn_hodgson
Re: turbo silencer removal?
« Reply #1 on: 27 October 2013, 19:26 »
or can it be removed?
Offline Dalo Harkin
« Reply #2 on: 28 October 2013, 09:10 »
On the turbo, its part if the casting so unless someone chopped it out and welded a new piece in....
In regards to the S3 charge pipe, I have the same setup and I know that Forge do one without the silencer but its not cheap and looks significantly longer than the standard one, maybe its just the images I've seen
Offline beppe2672
« Reply #3 on: 28 October 2013, 23:51 »
swap the comp housing, or chop and weld the existing one!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
jamie16v
« Reply #4 on: 29 October 2013, 13:53 »
+1 for the best answer so far, or even better, don't bother!
