Author Topic: Engine start blocked by immobiliser  (Read 833 times)
Offline stuby115bhp
« on: 27 October 2013, 11:38 »
Have an intermittent problem with immobiliser preventing engine start.  When this occurs it takes 4 or 5 attempts before normal starting is achieved. Tried changing key battery but still the same (both keys). When scanning it shows the following codes:
17978 engine start blocked by immobiliser intermittent
01176 key - signal to low intermittent.
Any ideas where to start with this one?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Engine start blocked by immobiliser
« Reply #1 on: 27 October 2013, 12:56 »
Knackered transponder in the key?
Offline stuby115bhp
« Reply #2 on: 27 October 2013, 15:31 »
I suspect it could be this as well but both keys I have started playing up within a short space of time.  Could it be the ecu?  The car has a misfire as well at the moment could these problems be linked? I believe there is more than one ecu on the car would the same one control both engine and immobiliser?
Offline EsSeX dAn
« Reply #3 on: 29 October 2013, 17:42 »
get the car scanned.
take off the ignition switch cowling and give the connector with the green wire and bkack wire a push/wiggle
i think i love you.....
