Author Topic: Should the top monts move on front shocks  (Read 3581 times)
Offline Shizzle
« on: 24 October 2013, 13:43 »
when checking my wheel bearing last night my complete wheel hub moved up and down not due to spring compression is this ok and if so how much movement should there be a colleague of mine had a very poor example of a mk3 golf and hes done this so now im slightly worried  :embarrassed:
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline bigberty101
Re: Should the top monts move on front shocks
« Reply #1 on: 24 October 2013, 14:28 »
sounds like your top mounts are shot, can get replacement ones with bearings from gsf for 10-15 notes a side. if your after oem ones that are better quality, the the mk2 g60 ones. or the next step is poly bush ones, little bit more expensive but 10x better than oem ones, just whatever you do, get bearings aswell
Offline Shizzle
« Reply #2 on: 24 October 2013, 14:31 »
where would i find the uprated ones i like to do a job once and do it right  :tongue:
Offline GOLF-MK3-GTI
« Reply #3 on: 24 October 2013, 15:05 »
febi are a good shout and very popular.
Offline Shizzle
« Reply #5 on: 24 October 2013, 15:16 »
wow thank you this will be one of my next purchases defiantly going with power flex bushes  :smug:
Offline bigberty101
« Reply #6 on: 24 October 2013, 15:56 »
no worries, powerflex are the ones to go for, last stupid amount lomger espically if your running low, will pay themselves off in no time, not to mention performance
Offline Shizzle
« Reply #7 on: 24 October 2013, 15:59 »
well at my company i get 20% off powerflex bushes so will pay for themselves very quickly :)
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 24 October 2013, 18:36 »
Febi are bogus. Lemforder is the ones to go for as everyone says but dont uold my word for it as i dont know how long they last. I have replaced mine with febi twice now and im sure they are fooked already and its only been 6months and i dont drive much either
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Foreveryoungaus16v
« Reply #9 on: 24 October 2013, 18:55 »
Mine need replacing. Thinking powerflex top mounts
163 BHP (TSR POWER RUN)
