Author Topic: Boot locking problem  (Read 1698 times)
Offline scoobiedoo
« on: 24 October 2013, 13:43 »
Hi all, what happens is that the central locking doesn't
Pull the mechanism up straight when unlocking
I'm guessing a part is worn or come off
Any ideas???
Offline mike1990
Re: Boot locking problem
« Reply #1 on: 24 October 2013, 19:46 »
Yes, you need a new central locking mechanism
Offline dom
  • Back in a Mk4
« Reply #2 on: 24 October 2013, 19:52 »
Any ideas???
Just on the boot? It's common for the internals of the boot latch to fail, usually because the rear windscreen washer has leaked.
Offline scoobiedoo
« Reply #3 on: 24 October 2013, 22:29 »
There's no leaking from the rear washer it just stopped returning
To under the handle piece.How much would the mechanism  be
From a dealer does anybody know? Also part number for it?
Offline dom
  • Back in a Mk4
Offline 52GTIPETE
« Reply #5 on: 25 October 2013, 11:01 »
T might be worth checking the wiring loom to the top right of the boot lid also. Over time they break. If it does not lock or unlock on the central locking it could be this. Normally the boot latch not working causes the boot light to not work.
Offline scoobiedoo
« Reply #6 on: 25 October 2013, 11:30 »
Central locking moves it but doesn't move it back under the handle piece
If that makes sense??
Offline dom
  • Back in a Mk4
« Reply #7 on: 25 October 2013, 13:11 »
Check the latch has not disconnected inside then.
Offline barrym381
« Reply #8 on: 25 October 2013, 13:15 »
mine was the little plastic clip same as this vid  :smiley:
http://www.youtube.com/watch?v=b32FhE5XmFQ
