Author Topic: Track/tie rod buying-how hard can it be??  (Read 1998 times)
Offline John W
« on: 23 October 2013, 07:53 »
Guys
Took the 8v GTI for tracking yesterday. It didn't get done because the passenger side rod is bent and the end is seized onto the drivers! So I need to get a pair of rods. Tried several places who couldn't help because the application was "difficult" or the parts "special order"..I'm confused as to why!
I know from research that there are two types of PAS rack on the MK3. Mine appears to have a smooth outer casing, which I think makes it TRW as opposed to ZF-is that right? I assume from the answers I've already had that the rods are different in some way? Also, are the track rod ENDS all the same or are there two types of those too?
I just want to make quite sure I get the right parts before stripping everything down......
Cheers.
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
Offline GOLF-MK3-GTI
Re: Track/tie rod buying-how hard can it be??
« Reply #1 on: 23 October 2013, 10:43 »
Have you tried GSF? I know they stock TRW parts for the Mk3 as i bought some ball joints for my MK3 from them.
Offline ant_gti
  • mk3 20v turbo
« Reply #2 on: 23 October 2013, 14:23 »
Ecp should be able to tell you what is fitted,as they did with mine which was trw
Offline John W
« Reply #3 on: 23 October 2013, 14:28 »
Thanks chaps. Contacted a very helpful guy on eBay who checked and is supplying me with the correct parts, including the ends.
Kind regards
John
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 23 October 2013, 15:26 »
only 1 set of track rods for the mk3
(I have sold/changed lots over the years and they have all used the same part, internal thread: M 14 x 1,5 outside thread: M 12 x 1,5 ends)
Offline gasketface
« Reply #5 on: 26 October 2013, 20:49 »
As above.All gti track rods are the same.The splines on the steering u/j shaft are the things that differ.
Offline John W
« Reply #6 on: 28 October 2013, 17:37 »
All done. Two new rods with ends for £25 and a boot kit for £12, fitted and tracking done for £60. Less than £100 for the whole lot. Not too bad, I don't think.
Kind regards
John
