Author Topic: Forge 007p updated piston / Servicing kit - Get one!  (Read 6165 times)
Offline Jin_C
« on: 22 October 2013, 11:44 »
Just posting to say that I have replaced the piston in my diverter valve and serviced it with new o-rings and it has completely transformed the car.
When I opened it up the, o-ring at the top which pushes against the screw top had a slight split in it so was dropping the piston a bit too much during the pen test.
The car has never really run that smoothly, minor fluctuations on idle and never providing smooth constant speed when on boost. I had checked all pipes, coilpacks, IAT, MAF, plugs etc even started replacing crank and knock sensors. I checked the spring in the valve which is still strong and did the pen test a long time ago but never thought to check if boost was passing through between the two larger ports.
This change fixed it and car is much smoother now.
p.s. This might not fix your issues but fully test your valve if you're having boost leak (non-smooth running) related issues
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline davemk4
Re: Forge 007p updated piston / Servicing kit - Get one!
« Reply #1 on: 22 October 2013, 12:28 »
Same with me few months ago runs miles better
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline james2
  • No scammers please.
« Reply #2 on: 22 October 2013, 12:42 »
Mine has minor fluctuations on idle ,might have a look at getting a kit.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dom
  • Back in a Mk4
« Reply #3 on: 22 October 2013, 12:44 »
How old was the valve before you serviced it?
Offline Jin_C
« Reply #4 on: 22 October 2013, 13:18 »
I bought it second hand so I am not quite sure
Offline baxxy
« Reply #5 on: 23 October 2013, 00:31 »
If you speak nicely to the guys at forge they will send you a service kit out for free  :smiley:
Offline xtetx
« Reply #6 on: 23 October 2013, 12:49 »
mine has no leaks at all since the service, i had a brown stain at the bottom where the piston moves up and down. So it is deffo worth it.
Offline baxxy
« Reply #7 on: 23 October 2013, 13:04 »
You always have a brown stain sumwhere or other mate haha
Offline Jin_C
« Reply #8 on: 23 October 2013, 15:37 »
Yup, good customer service from Forge, they sent mine for free.
hehe brown stain
Offline xtetx
« Reply #9 on: 23 October 2013, 15:46 »
hahahaha  :laugh: :laugh: :laugh:
