Author Topic: Great just spends a best part of a grand on wheels then.......  (Read 4922 times)
Offline Nino
So been thinking to myself of some time now, "Right Nino, the golf has been fine for almost 6  months something is due" So coming home today and pulled up outside my house (I live in a culdasac) so I drive in, turn right, full lock left and reverse and stop right outside my house.
So... I turn right and hear a whine, into reverse and turn left, with that I hear a whine that can only be discribed as a whineing gearbox... at this point my heart sunk!  :embarrassed:
Then I turn the car off and pop the bonnet, to find everything looks normal, I glace to my right and right where I stopped and turned right there is what can only be discribbed as small oil patch rainbow splat, about the size of a dominos pizza.
I start to think oh god my gearbox is dead  :cry:
Then I start the car again and move it forward and back abit to which there is no noise, I even move the steering about abit and nothing.  :undecided:
So then I rang me mate to which he said his company van (VW caddy) did the same thing a few weeks ago and it turned out to be a split power steering pipe.
When he got here we moved my car and spotted a bigger rainbow splat, looks like its directly below the back end of my engine at a rough guess.
So we checked the level of the power steering fluid and it was empty  :shocked:
With that we jumped in his van and off to halford as there were the only place open  :angry:
£14.99 lighter for halfords special (I know its cheaper from VW don't go there lol)
So filled the fluid up which strangely enough didnt take much at all  :huh: started the engine and proceeded to turn the steering wheel left and right for about 2 mins, each time I was getting close to the full lock I could hear the pump working and the fluid level was dropping but then the level went back up when I took the pressure off. Same happened when I full locked the other side. This just repeated for awhile then my friend said he saw a massive air bubble pop out then my steering went a tiny bit lighter.
After that we took the drive for a 2 mile ish drive and the car drove perfectly fine infact my steering felt alot lighter than I remember it. Got back home no noises, no problems, checked the fluid level and there was no change BUT I did notice some small spots of the fluid on the floor again in a line where I pulled in on the right, and there is a small spot under the car again.
The smell of the stuff on the floor is almost the exact same smell as the replacement fluid I just sourced but oviously its abit different because its mixed in with the old fluid.
I am worrying now because I need my car for work, I travel 40 miles a day for work and I am worried if I should drive or if its safe to drive or not plus I cannot afford to take time off work.
Also i am not 100% certain is is the power steering ratelated hence why I am posting here, in your opinions guys would this point to the power steering or do you think its something else and the fact that my fluid level was empty was just a coincidence and bad luck.
In all fairness I have owned my car since april last year and never thought to ever check my power steering fluid.
I am booking my car into my garage for saturday (earlyest I can do it) Do you think it will be safe to use the car for work until then? my plan is to check the fluid level in the morning and top up if needed, then drive to work and check the fluid when I get there and in between that just ensure the levels are topped up..
Poor GTI_James just had me in his ear for like 30mins giving me advise but being me I wanted to check with you lot as well :)
Sorry for the essy but think of it as your reading for the week done  :cool:
« Last Edit: 21 October 2013, 19:26 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline richw911
Re: Great just spends a best part of a grand on wheels then.......
« Reply #1 on: 21 October 2013, 19:47 »
Leaking steering rack........
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 21 October 2013, 19:50 »
Don't worry about it to much unless its pi$$in out (think of the two wheeled vehicles),the noise will be a dry pump ,its obvious you are losing fluid so keep it topped up between journeys and get it looked at when you can
Offline dom
  • Back in a Mk4
« Reply #3 on: 21 October 2013, 19:58 »
Get under the car and clean any fluid that you can see, check it again after a drive to see if you can work out where it's coming from. My money would also be on the rack.
Offline Nino
« Reply #4 on: 21 October 2013, 20:00 »
Funny you should say that, I had an advisory on my MOT for "Play in the steering rack" could you give me more detailing on where/what could be leaking please?
Offline james2
  • No scammers please.
« Reply #5 on: 21 October 2013, 20:10 »
It will be fine just a small leak in a pipe. As above check it everyday after work to see how much is lost. Carry spare fluid with you if you are worried.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 21 October 2013, 20:31 »
Get some VW fluid in there once it's sorted though mate, it's very different from anything Halfords sell
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #7 on: 21 October 2013, 20:43 »
Oh damn i got and advisory on my recent MOT for a Play in the steering rack to, well gonna get that fixed asap now!!
« Reply #8 on: 21 October 2013, 21:20 »
Clean it all off (brake cleaner etc) then park on a clean part of the floor and look to see where it is leaking.
Offline Rhyso
« Reply #9 on: 21 October 2013, 22:54 »
Sounds like the rack. Only option is to replace
Think Rich and a few others used someone on Ebay who supplies new ones on exchange basis so you send your old rack back  :undecided:
