Author Topic: oil level help  (Read 2103 times)
Offline wsmith
oil level help
« on: 20 October 2013, 20:38 »
hi i changed my oil and filter yesterday and when i checked it today it was just above the max mark by a little bit will it be ok to leave it ,if not whats the best way to get the oil out with out loseing the lot
Offline Screech16v
  • MK3 20vt AGU
Re: oil level help
« Reply #1 on: 20 October 2013, 22:43 »
It will probably be ok if driven sensibly ,but start thrashing it and you run the risk of extra crankcase pressures which may cause you some unwanted oil leaks,best undo the sump plug whilst engine is cold and let out what you don't need.
Offline A5H
  • MK4 1.8 Turbo
Re: oil level help
« Reply #2 on: 21 October 2013, 00:10 »
I would take some out
As said if you undo it with the engine cold you should be able to get the plug back in no problem
Offline wsmith
Re: oil level help
« Reply #3 on: 21 October 2013, 07:29 »
cheers i wil do that today
Re: oil level help
« Reply #4 on: 21 October 2013, 21:46 »
I would not recommend this idea as it will be unholy mess, better to use a syringe and some clear plastic tubing and suck out a little bit.
Offline Screech16v
  • MK3 20vt AGU
Re: oil level help
« Reply #5 on: 21 October 2013, 23:08 »
Only a mess if your a blithering idiot and cant control your own hands.
Re: oil level help
« Reply #6 on: 21 October 2013, 23:42 »
Have you ever tried refitting a drain plug after only trying to let a little oil out  :undecided:
Offline mcgee9t2
Re: oil level help
« Reply #7 on: 22 October 2013, 12:40 »
+1 on what wayne said.
would be easy to remoe it till its on the last thread and let the oil drip out then re-do, but you would be there for days waiting. id suck it out the oil refill hole.
Offline Screech16v
  • MK3 20vt AGU
Re: oil level help
« Reply #8 on: 22 October 2013, 18:59 »
Yes ive done it countless times , i would never give out advice on things I know nothing about ,you don't remove the plug completely just pull it away some.
Offline topher
  • Administrator
  • fully functioning
Re: oil level help
« Reply #9 on: 22 October 2013, 21:10 »
unwind it till it's loose, hold it at an angle and pop it back in.. isn't hard. if you do happen to have a big syringe and a long thin tube handy it does save you having to crawl around on the floor though!
