Author Topic: Boot light bulb  (Read 2344 times)
Offline Scottymk4
Boot light bulb
« on: 20 October 2013, 10:26 »
What bulb does interior boot light take? Thought it was same as visor lights but it's not
Cheers. Scott
« Last Edit: 20 October 2013, 10:29 by Scottymk4 »
Offline dom
  • Back in a Mk4
Re: Boot light bulb
« Reply #1 on: 20 October 2013, 10:51 »
It's a festoon bulb isn't it? Just take it out and measure it
Offline Scottymk4
Re: Boot light bulb
« Reply #2 on: 20 October 2013, 10:55 »
Don't have one in there but doesn't look like a festoon one as it only has one end
Offline dom
  • Back in a Mk4
Re: Boot light bulb
« Reply #3 on: 20 October 2013, 11:00 »
I'll have a look in a bit for you to see what mine is
Offline Scottymk4
Re: Boot light bulb
« Reply #4 on: 20 October 2013, 11:01 »
Cheers dom
Offline davemk4
Re: Boot light bulb
« Reply #5 on: 20 October 2013, 12:13 »
Mines a 501 wedge bulb
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Scottymk4
Re: Boot light bulb
« Reply #6 on: 20 October 2013, 12:28 »
Thanks Dave that's what I was thinking it could be
Offline harlemex
Re: Boot light bulb
« Reply #7 on: 20 October 2013, 12:33 »
I bet replacing the bulb wont work.... :lipsrsealed:
Offline Scottymk4
Re: Boot light bulb
« Reply #8 on: 20 October 2013, 12:35 »
Why ?? :sad:
Offline mcgee9t2
Re: Boot light bulb
« Reply #9 on: 20 October 2013, 13:29 »
he says he hasent got one in there atm thats why he is replacing it...
common problem for the boot to get wet from the washer jet and feck up the boot switch and other electronics.
