Author Topic: Mass air flow sensor wire (plug) ( gti dsg 55 plate)  (Read 2654 times)
Offline Vwgti779
« on: 20 October 2013, 09:53 »
I have a problem with the air plug, one of the wires have come away, I was driving the car and could feel the obvious pull on the engine. My garage man can't do anything till Monday (tomorrow) when I started the car yesterday it was really juddering, will I still be able to drive my car to the garage? Help!! :sad:
« Last Edit: 20 October 2013, 09:58 by Vwgti779 »
Offline Wazzzer
  • Golf GTI 1.8T AGU
Re: Mass air flow sensor wire (plug) ( gti dsg 55 plate)
« Reply #1 on: 20 October 2013, 10:02 »
unplug it for the journey to the garage
Offline Vwgti779
« Reply #2 on: 20 October 2013, 10:08 »
Ok I will. But just wondering if it will make any difference with it plugged in, as only one of three wires have come away.
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #3 on: 20 October 2013, 10:10 »
It won't be too happy with only two wires getting a signal, if you unplug it you'll run a safe base fuel map which will be fine
Offline Vwgti779
« Reply #4 on: 20 October 2013, 10:16 »
Ok thanks for your help
Offline dom
  • Back in a Mk4
« Reply #5 on: 20 October 2013, 10:52 »
If it's a 55 plate with dsg then it's a MK5 and in the wrong section. If you can confirm this either myself or Wazzzer will move it into the correct place :wink:
Offline Vwgti779
« Reply #6 on: 20 October 2013, 13:04 »
Yes it is a mk5
Offline Vwgti779
« Reply #7 on: 20 October 2013, 14:02 »
I have just taken the plug out but the engine sounds so sick ( sounds even worse with the plug in) the garage is a 10-15 min drive, will it be ok to drive  Or should I just get it towed?
« Last Edit: 20 October 2013, 14:29 by Vwgti779 »
