Author Topic: forge actuator needed for stage 2?  (Read 1780 times)
Offline davemk4
« on: 20 October 2013, 08:01 »
My car boosts to stage 1 mapping no smoke no issues. But when i come togo stage 2 is an upgraded actutor worth it or needed??
If so are they a pig to fit? And how do you set them up?
Anything else id need
Items that are on or will be on by time i go
Air filter apollo k&n
New n75
Forge 007 yellow spring
Enlarged TIP
2.5" fmic
3" decat/downpipe
2.75" cat back
N249 delete
Superunleaded at all times
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: forge actuator needed for stage 2?
« Reply #1 on: 20 October 2013, 10:09 »
They give a much better response with boost and chances are your current actuator will be past its best anyway. It's a manifold off job to fit them so budget a few hours and some new gaskets etc. Measure your current actuator and set the length the same as that for the first run, disconnect the N75 plug and see how much boost you get. Around 8psi will be fine. You can add more preload (shorten the rod) if needed but don't go crazy or you'll have major problems
Don't replace your N75 unless it's knackered, I'm still running a C version that's about 12 years old and it's fine.
If you go with a K&N make sure it's not oiled otherwise it will shorten the life of your MAF
Offline davemk4
« Reply #2 on: 20 October 2013, 10:14 »
well all ready got anew n75 on....  sounds like fun replacing the actuator then not too sure on it then lol ill see what me dad says as he be the one fitting that :)
my k&n is a apollo filter i havnt oilled it but im sure these come pre oiled..my maf brand new genuine too. so that might bugger me maf then?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 20 October 2013, 10:32 »
it may do mate as it can draw the oil through onto the element. As long as there's not masses of oil on it you should be ok
Actuator isn't too bad to change, it just takes time trying to find all 13 of the nuts to get the manifold off. You need to dro the turbo down slightly to get at them all too but not completely remove it. I left mine on the downpipe
Offline davemk4
« Reply #4 on: 20 October 2013, 10:52 »
Argggg but i like my k&n. Lol i dont like piperx, quikshift look dated,  could get a jetex one maybe.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 20 October 2013, 13:22 »
Get a dirty great big Pipercross cone like I have
Offline davemk4
« Reply #6 on: 20 October 2013, 13:26 »
would a 2.25'' intercooler be ok im looking for aroung the 220-230bhp mark?
Offline Chris.
« Reply #7 on: 03 November 2013, 18:49 »
Would get away with it. but better to fit 2.5"
Click For Build Thread
