Author Topic: MK4 1.8T 150 Cold Start Issues  (Read 1286 times)
Offline swgolfchap
« on: 19 October 2013, 23:29 »
Hi,
Got a mk4 1.8t 150bhp 2003 plate. When i cold start it i get a buzzing sound / hissing sound for about a minute and the rev counter flicks up and down until after the minute then it all calms down and back to normal. Sorry if my description seems odd, cant explain it really! Any ideas chaps?
Cheers,
Offline dom
  • Back in a Mk4
Re: MK4 1.8T 150 Cold Start Issues
« Reply #1 on: 20 October 2013, 00:39 »
Secondary air pump would be my guess.
Offline swgolfchap
« Reply #2 on: 20 October 2013, 01:31 »
Hi,
Cheap part? Worth replacing or is it just a noise for now?
Cheers,
Offline dom
  • Back in a Mk4
« Reply #3 on: 20 October 2013, 10:57 »
I removed mine, all it does is pump air into the cat upon start-up, I'm not running a cat so I don't need it.
If it is the SAI at fault then you can see if you can repair it:
http://uk-mkivs.net/forums/t/141240.aspx
Or remove it all together, there is a section in this link that shows you how:
http://forums.vwvortex.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
Offline swgolfchap
« Reply #4 on: 25 October 2013, 13:46 »
Sods law i`m flying out to spain tonight and guess what... Engine management light and the traction control light comes on! Car seems to work but if i go around 3000 revs i get a drop then the turbo kicks back in... Not sure about this one chaps?
Cheers,
