Author Topic: Mk3 Bottom end  (Read 1802 times)
Offline scottyfalmouth
Mk3 Bottom end
« on: 19 October 2013, 20:36 »
Right on.
Got the car in bits in the garage replacing gear box. Someone mentioned I should whip the engine out and put a mk3 GTI 2L bottom end on.
Any thoughts?
Offline gazareth
Re: Mk3 Bottom end
« Reply #1 on: 19 October 2013, 22:46 »
gives you a good increase in torque but doesn't rev quite as well as the 1.8. but if you have a cam or head upgrade in mind then go for it. you will need to uprate the front suspension slightly as the 2.0 bottom end is heavier. not by much but you can notice it when cornering.
Offline mad4vws
Re: Mk3 Bottom end
« Reply #2 on: 20 October 2013, 13:16 »
i have a complete 20e mk3 2.0 engine if u do got every thing apart from the dizzy based in Birmingham... :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
